Results 1 to 7 of 7
    Aug 2015
    Snapped Workmate's Frame - Advice Needed!
    Seem to have cracked the chainstay on a colleague's Mongoose Salvo Elite 2011. Either that or I didn't notice the damage when I borrowed it (should have checked it first!)
    Has anyone got any suggestions re: a suitable replacement frame? Thanks in advance!
    May 2014
    Have a Frame Builder repair it.
    Aug 2015
    Quote Originally Posted by tiretracks View Post
    They're annoyingly thin on the ground in my part of the UK. I'm trying to source a replacement part - the rear chainstays are a separate piece of metal on this model, fortunately. Unfortunately I can't find new one.
    Looks like a job for a welder...
    Professional Slacker
    Depends if you crashed and damaged it (yes) or if it's just a stress fracture from use (no).
    Aluminum isn't great for repairs. If it's not from a crash and your friend is the original owner, I'd contact Mongoose to see if they'll warranty it. In the US, frame warranty on alu frames is 5 years for the original owner. Not sure about UK, but worth a shot. Stop by a dealer and see what they have to say. Can't hurt - maybe they'll give you a discount on another as a crash replacement.
    Jun 2013
    Quote Originally Posted by richde View Post
    That's what I was thinking. How did this happen?
    Quote Originally Posted by noapathy View Post
    Aluminum isn't great for repairs...
    +1, I'm no expert but from what I know, the part is likely to fail if not heat treated after being welded. For a single frame, this is cost prohibitive. Around me they charge just over $200 to do it... but that pricing is for up to 20 frames. So, yeah, if you can find someone who specializes in aluminum it would be cheaper. Find a place that does the heat treating and see if they can recommend a welder.
    Aluminum Workshop: Achieving T6 designation for 6061 - TheFabricator.com
    Killing it with close inspection.
  1. 29er frame advice needed
    By matesan in forum 29er Bikes
    Last Post: 08-31-2014, 05:00 AM
  2. Internal gear routing in advice frame- advice needed
    By woody74 in forum Frame Building
    Last Post: 01-14-2014, 06:34 PM
  3. 29er Frame Fitting - Advice needed
    By Eric Taylor in forum 29er Bikes
    Last Post: 10-15-2013, 08:54 PM
  4. Frame Size Advice Needed
    By wheeljack in forum Beginner's Corner
    Last Post: 04-23-2012, 06:57 PM
  5. Frame Building 101 Advice Needed for Newbie
    By SweetDoug in forum Frame Building
    Last Post: 01-02-2011, 01:31 PM
Can't find it? Just search our site!
