    Jul 2013
    Shorter seat tubes for more clearance?
    Hi, I'm new to understanding the science of bicycles and whatnot and was curious about the idea of a shorter seat tube and how it supposedly gives you more clearance.
    I keep reading that due to the shorter seat tube you need to run a longer seat post and have more of it stick out of the seat tube...Why is that?
    Also, how does the longer seatpost then absorbs more bumps and make for a more comfortable ride? Is it simple because more seatpost means more flex and it's not as stiff?
    Thank you.
    dru
    dru is offline
    'More clearance' means more clearance between the family jewels and the top tube of the frame.
    If you have a 'shorter seat tube' then obviously you'll need to have more of the seat post sticking out for a given saddle height.
    Yes, a longer seat post will flex more than a short one giving perhaps some compliance.
    Drew
    occasional cyclist
    Jul 2013
    Thank you so much.
    Does the sloping top tube play into this? Because it's sloping downward towards the seat tube it allows for a shorter seat tube and thus making you use more seatpost?
    Reputation: seat_boy's Avatar
    That's exactly it. If you look at old (80s) mountain bikes, most of them had level (or nearly so) top tubes, like road bikes. But, mountain bikers found they enjoyed the extra standover clearance, so sloping top tubes have taken over.
    Quote Originally Posted by Mtrain17 View Post
    Thank you so much.
  1. Shorter chainstays and tucking the rear wheel under the seat?
    By AZGroundPound3r in forum Bike and Frame discussion
    Last Post: 07-25-2012, 04:06 AM
  2. 2011 X-Cals and Cracked Seat Tubes
    By gdv in forum Trek
    Last Post: 06-13-2012, 10:18 PM
  3. Short seat tubes and long top tubes, WTH?
    By IMBAcile in forum 29er Bikes
    Last Post: 02-05-2012, 06:44 PM
  4. N-Gear with large seat tubes
    By Dictatorsaurus in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-13-2011, 06:51 PM
  5. Shorter cranks + rock clearance
    By dwt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-20-2011, 12:41 PM
