Results 1 to 9 of 9
    Seatpost Metal Shavings; Wrong Size?
    So I'm building up an old frame which didn't have a seatpost when I got it. A 26.0mm seatpost fits but needs a lot of zig-zagging and some coaxing back and forth to work its way down. Is that too tight, and should I step down to a 25.8mm?
    Seems like a kind of easy question -- any thoughts??
    Re: Seatpost Metal Shavings; Wrong Size?
    Have you ever needed zig-zag coaxing to get other seatposts in while creating metal shavings?
    You should probably try out a few and go with a snug post but not one that's so snug its shaving away metal
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Quote Originally Posted by Jonmustang View Post
    A pair of calipers or some internet research will help you find out what size the tube currently is. If you're shaving metal I would suspect it's a bit too tight, but you never know. You could possibly hit it with a ball honer and smooth things out.
    Quote Originally Posted by zebrahum View Post
    Yea, the seat-tube measured an I.D. of 25mm... however a LBS had a little seatpost tube gauge thingy that drops down into the tube, and that one came out "just about 26.0mm", to quote the mechanic. So that's why I tried the 26.0 despite roughing up the post a little teeny bit. Didn't manhandle it, just let it go down snug.
    I can't remember how I.D and O.D. between posts and tubes is matched... if anyone wants to save me a few minutes of Googling, please shout it out!
    BTW, the reason I wouldn't just go try a couple different sizes is that this is a cheapskate bike build and I'm trying to go with used parts; thus, I don't wanna have to track down and pay for a used part just to have it be slightly wrong when I get home.
    Picture Unrelated
    Jun 2005
    Kalloy seatposts are something like $15 new retail price. But the difference between 26 and 25mm is huge as far as seatposts go. Maybe hone it a bit?
    I meant take it to your lbs and try a couple different sizes.
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    Find someone with a ball hone and hone the seat tube. Sometimes seatposts are a tight fit even on brand new bikes. Sounds like 26.0mm fits, this would get rid of the zig-zagging issue.
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
