Results 1 to 5 of 5
Thread: Seat Tube angle
    Reputation: jazzanova's Avatar
    Seat Tube angle
    How does it effect the geometry of a bike?
    I am considering offset bushings for my SC Tallboy to slacken the head tube a bit.
    It will also slacken the seat tube which by my understanding doesn't have to be necessarily a good thing.
    I have also noticed the trend in progressive geometry to go with steep ST angles.
    So, how is it going to change my ride?
    Offset bushings - Anything else I should be aware off?
    Reputation: shiggy's Avatar
    Dec 1998
    Seat Tube angle
    Quote Originally Posted by jazzanova View Post
    You will need to move your saddle forward to keep the same position over the pedals, and this shortens your reach to the bars, which may require a long stem, which moves your weight more towards the front wheel...
    mtbtires.com
    Re: Seat Tube angle
    Thanks Shiggy.
    Do you know how much adjustment in the seat position we are talking about?
    Sent from my PG86100 using Tapatalk 2
    Dec 1998
    Seat Tube angle
    Thanks Shiggy.
    Depends on the amount of change.
    Measure before and after. Adjust to match.
    mtbtires.com
    Reputation: GTscoob's Avatar
    Quote Originally Posted by shiggy View Post
    This is the easiest way or you can bust out a calculator and do some trigonometry.
    Make a triangle between your saddle and bottom bracket with the existing known seat tube angle and height difference, adjust the angle and see how far your saddle moves back with the slacker STA.
  1. seat tube angle - chilcotin
    By cfrench in forum Knolly
    Last Post: 03-19-2015, 10:26 AM
  2. Seat tube Angle & pedaling comfort
    By zephxiii in forum Bike and Frame discussion
    Last Post: 03-02-2013, 05:02 PM
  3. Determining head and seat tube angle
    By rev106 in forum Frame Building
    Last Post: 02-23-2012, 02:32 PM
  4. Replies: 10
    Last Post: 02-22-2012, 11:02 PM
  5. Seat Tube Angle (Effective) - Low Setting
    By twenty6black in forum Specialized
    Last Post: 07-22-2011, 11:46 AM
