    Reputation: makomyday's Avatar
    Rockshox Ario 2.1 on my Felt Compulsion
    Brand new bike, 2010 Felt Compulsion with the the Ario 2.1 rear shock. After the first ride the o-ring that shows length of travel on the piston seamed to be a bit moist with oil. It was dry prior to the ride.
    This is my first Air Shock. is this normal? Seams to hold pressure and dampening/rebound adjustment just fine.
    Thanks for your input!
    CHOP!
    Reputation: MartinsMental's Avatar
    Dec 2005
    Totally normal.
    What you're seeing is the shock's lubrication. New shocks will break in over the first few rides and the lube will stop seeping after a while.
    Just keep an eye on it and wipe off the excess lube before you ride.
    Ario is a sweet shock by the way...
    It's not where it's made but how it's made.
    meow meow
    Reputation: b-kul's Avatar
    normal, my ario 3.2 did the same thing. its been a great shock so far.
    SWEEET. Thanks!
