Results 1 to 5 of 5
    Jun 2010
    Rockhopper vs GF Wahoo vs Scott Aspect 30
    I am goint to be purchasing a bike soon and have been looking a lot. I thought I had it narrowed down between a base Rockhopper for $610 and a GF Wahoo for $500. However I just recently came across a new 2010 Scott aspect 30 for $600. I've listed the Aspect 30 specs below but which of the three is the best bike?
    Weight 12.90 kg / 28.41 lbs
    Frame New hydroformed Frame Alloy 6061 D.B.Performance geometry
    Fork Suntour XCR with Lockout 100mm travel Headset Ritchey Logic OE integ.
    Derailleur (Rear) Shimano Deore RD-M592 27 Speed
    Derailleur (Front) Shimano Deore FC-M590 34.9mm
    Shifters Shimano Deore SL-M590 R-fire plus 2 w/gear indicator
    Brake Levers Disc: Shimano BL-M486 V-Brake: Scott Comp
    Brakes Disc: Shimano BR-M486 Hydr. Disc V-Brake: Scott Comp V-Brake
    Crankset Shimano FC-M442 Octalink, silver 44Ax32x22 T
    BB-Set Shimano BB-ES-25
    Handlebar Scott Aspect OS 620mm, black, 31,8mm 20mm rise 8
    H'stem Scott Comp JD-ST57 A OS 31,8mm
    May 2010
    Have you ridden them all yet?
    Jun 2010
    Yes I have.
    I'd go for disc brakes.
    And the next question from gsxunv04 is probably going to be: Which bike fit the best? (Get that one. )
    May 2010
    I have a wahoo disc and so far it has done great. I live in WNC so I have a lot of rooty and rocky downhill trails which I ride. I had to replace to stock saddle(pain in the arse, literally) but other than that it is good to go. I agree with tmosher, def. get a bike with disc brakes.
    FWIW, my buddy has a rockhopper comp SL 29er, it is a sweet ride too.
