I am goint to be purchasing a bike soon and have been looking a lot. I thought I had it narrowed down between a base Rockhopper for $610 and a GF Wahoo for $500. However I just recently came across a new 2010 Scott aspect 30 for $600. I've listed the Aspect 30 specs below but which of the three is the best bike?
Weight 12.90 kg / 28.41 lbs
Frame New hydroformed Frame Alloy 6061 D.B.Performance geometry
Fork Suntour XCR with Lockout 100mm travel Headset Ritchey Logic OE integ.
Derailleur (Rear) Shimano Deore RD-M592 27 Speed
Derailleur (Front) Shimano Deore FC-M590 34.9mm
Shifters Shimano Deore SL-M590 R-fire plus 2 w/gear indicator
Brake Levers Disc: Shimano BL-M486 V-Brake: Scott Comp
Brakes Disc: Shimano BR-M486 Hydr. Disc V-Brake: Scott Comp V-Brake
Crankset Shimano FC-M442 Octalink, silver 44Ax32x22 T
BB-Set Shimano BB-ES-25
Handlebar Scott Aspect OS 620mm, black, 31,8mm 20mm rise 8°
H'stem Scott Comp JD-ST57 A OS 31,8mm
