    Sep 2015
    Rigid forks too long?
    Just built this Inbred using my Ebay Earnings and parts from cellar. Used to 90s MTBs and road bikes so this feels slack to me. Forks are Surly 1x1 (453mm A-C) suspension corrected for 100mm, though On-One's own cromo 100mm corrected forks are 440mm A-C.
    Most 26er 100mm sus forks seem to be in the 470s without sag, so this seemed reasonable to me when buying, but looks huge to me with 2.1 tyres.
    Does flex a bit when braking...
    Attached Thumbnails Attached Thumbnails Rigid forks too long?-img_20160502_155023618.jpg
    I live to bike
    Reputation: Jwiffle's Avatar
    Looks fine to me, but the seat's not level.
    Stop in at Element Sports. www.elementsport.com
    Get Out! Have Fun!
    Give'er!
    Reputation: MCHB's Avatar
    Jun 2014
    Looks good to me (guessing you haven't cut the steerer tube yet)! The suspension corrected rigid forks look big because they don't have the bridge...thing...over top of the wheel that their suspension counterpart has.
    If you look at (most) 90's rigid bikes, they typically had longer head tubes and different geometry that resulted in shorter stanchions; they weren't built to replace longer travel suspension forks as they were designed rigid.
    If you need to finetune for sag, you can, at least to some extent, play around with your spacer stack.
    When I converted my 26 to rigid, I used the nashbar cro-mo one which has an axle-crown measurement of 453mm (which was pretty close to my old forks unsagged measurement); it replaced a suntour xc fork with 63mm of travel. I wound up putting one 5mm spacer over the stem and left the rest where they were.
    Give'er!
    Jun 2014
    Fwiw,
  1. Why Rigid Forks?
    By shreddr in forum Singlespeed
    Last Post: 06-15-2015, 12:28 PM
  2. Been riding rigid for so long I know nothing about forks!
    By robtre in forum Shocks and Suspension
    Last Post: 04-08-2015, 09:18 AM
  3. Why Rigid Forks?
    By shreddr in forum Niner Bikes
    Last Post: 02-18-2015, 08:14 PM
  4. To rigid or not to rigid? FORKS
    By bald dirt bag in forum Urban/DJ/Park
    Last Post: 01-22-2015, 09:58 AM
  5. 410 rigid forks
    By fotu in forum Bike and Frame discussion
    Last Post: 03-26-2013, 02:46 PM
