Results 1 to 3 of 3
    Oct 2013
    rigid fork for cannondale 2002 f400
    Hello, Im new to this forum and was wondering what size and brand or model rigid fork I could use on a 2002 cannondale f400, or at least a better shock then what is stock for this bike.as of now I have the frame only.thank you for any advise.
    Dec 2010
    Does the frame you have currently have a headset? I would probably suggest getting a new headset so that you have all the pieces (i.e. crown race) and something that will work in your frame (meant for a 1.5" steerer tube) and will reduce down to a regular 1-1/8" headset. That will open up some fork options for you, rigid or suspended.
    Your bike originally came from the factory with the Headshok P-Bone M fork which had 60mm of travel. You can buy the original fork from eBay right here if you wanted to keep it somewhat original. Cannondale P Bone M 60mm Headshok MTB Suspension Fork Black | eBay Otherwise you'll be looking for a fork with 60mm of travel which is going to be hard to find. As far as a rigid fork goes, you'll probably be looking for something with around a 400mm axle-to-crown length (that would be my guess).
    It may be worth bringing up this topic in the Vintage, Retro, Classic thread as they will be able to help you out a bit more.
    *edit* keep in mind that you're also looking for a fork with v-brake studs, as your bike (according to bikepedia does not have disc brakes). If all else fails, contact a couple frame/fork builders and see what they can make for you.
    Oct 2013
    thank you,
  1. Replies: 3
    Last Post: 08-13-2013, 05:12 PM
  2. please delete
    By discohospital in forum Cannondale
    Last Post: 07-20-2013, 01:54 AM
  3. Cannondale F400 handlebars
    By DaveMc in forum Tooltime
    Last Post: 05-07-2013, 06:25 AM
  4. Cannondale F400 All Mountain
    By linedpaper in forum Beginner's Corner
    Last Post: 05-03-2013, 03:26 PM
  5. Cannondale F400 - Should I upgrade parts or buy new bike?
    By interdigitate in forum Bike and Frame discussion
    Last Post: 07-18-2011, 09:41 AM
