    rear derailleur suggestions, please
    I have 1 x 8 with a 38 front ring and I put on a new cassette with a 34 low gear. I have a Avilio derailleur and shifter. I can find all the gears, it's just not very consistent, smooth, etc. Any suggestions on an up grade?
    dirtbag
    Reputation: ranier's Avatar
    Sep 2003
    You can't go wrong with Shimano XT or Sram X.9 but you'll have to go 9 or even 10spd if you want new stuff.
    Gonna be hard but not impossible to find and 8spd XT shifter. Check used on fleabay.
    Amolan
    Before making any changes, you may want to make sure the cable isn't sticking and the hanger is straight. Either can affect shifting more than the difference between component levels.
    I'm always amazed at the difference a $5 cable can make when I change it every year.
    Oct 2007
    You can use any 9 speed derailleur on an 8 speed system. A Shimano SLX or XT would both be significant improvements over your Alivio.
    2015 Niner Jet 9 Carbon
    2014 Focus Raven 27R
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
