Results 1 to 6 of 6
    Mar 2013
    question about thru axle on Trek Stache hardtail
    Hey all,
    A couple weeks ago I purchased a Stache hardtail and I am loving it.
    My question is that on the last ride for whatever reason I noticed after getting back to my house the thru axle QR lever was not tightened down, and either was loosened at some point or possibly even from the LBS. I noticed it because I could hear/feel jiggling in the rear end. I have tightened it down and still feel like there is some play and a very slight noise when I take the rear wheel and move it side to side while holding the frame.
    Is is possible I damaged anything with the frame by riding with the thru axle loose for one ride?
    Did you ever find out what the problem was? I have the same problem and I'm taking mine to the shop tomorrow. I have heard that it may just be a cheap axle or a frame alignment problem.
    Apr 2013
    So I just had this same issue. However I never had my thru axle loose. Bike is only a few weeks old and only ridden about 5 times. 2015 Trek Stache 7, did anyone find out what the issue was?
    Reputation: brent701's Avatar
    Sep 2012
    sounds like the hub is loose.
    tighten it and the wheel will stop wiggling.
    I have mine gone through once a month. When it gets loose it drives me nuts while I ride
    Too Many .
    Apr 2013
    Well that seems to be what it was shop tightened the hub, wiggle is all gone but now the wheel doesn't spin nice and freely so I think they over tightened a bit much. Ill have take it back tomorrow and see what they can do.
    Apr 2013
    So took it back to the shop they loosened it a bit so the wheel spins more freely. But now there is a real slight amount of play and they said that is as good as it's going to get without binding the wheel a noticeable amount.
  1. Highball AL vs Trek Stache?
    By sandyeggo in forum 29er Bikes
    Last Post: 06-08-2013, 07:11 PM
  2. Trek X-Caliber vs Trek Stache 7
    By joshm8979 in forum Trek
    Last Post: 06-07-2013, 05:18 PM
  3. Stache 8 rear axle issue
    By jcerion929rr in forum 29er Bikes
    Last Post: 04-26-2013, 05:48 PM
  4. Trek Stache.
    By dubdryver in forum 29er Bikes
    Last Post: 03-26-2013, 08:05 AM
  5. Trek X-Caliber or Stache 7 ???
    By Ufdah in forum 29er Bikes
    Last Post: 11-15-2012, 10:26 PM
Members who have read this thread: 7
