Results 1 to 9 of 9
    Jun 2014
    Putting Bar Ends on my MTB -- What grips to use?
    So, I'm gonna add some bar ends to my MTB for comfort purposes. Right now my bike has closed-end ergo grips from Specialized. What are some good grips that are open-end so I can slide the bar through for room for bar ends? I see some I like online, but there's no spec stating if they are open or closed ended.
    Not looking for anything special, something like this would be perfect.
    Specialized Bicycle Components
    Thanks all!
    You can always just cut the ends off of the grips.
    Reputation: GOTA's Avatar
    Oury lock on grips are great. They have many different options to suit whatever style fits you.
    He who dares....wins!
    Nov 2007
    I no longer use bar ends, but when I did I found that during long climbs my hands would rest on both the bar ends and grips, and it would often get very uncomfortable at the spot that rested on the grips. Solved the problem with ESI Extra Chunkies, which I still use and love, despite the fact they're not particularly durable.
    MTB Grips
    If you like an ergo-style grip, you might consider Ergon GS2. The bar end is part of the grip. It alleviates the junction issue Itspd1 mentions above. Throngs of adventure/endurance cyclists can't be wrong
    ^^^ this
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Re: Putting Bar Ends on my MTB -- What grips to use?
    Careful, since bar ends are not as popular these days, many modern bars are not built to take that kind of compression and leverage on the end.
    I'm unsure if this is a problem with those integrated grip / bar ends since they may distribute the load further inboard if they are sufficiently rigid.
    Aug 2014
    Quote Originally Posted by Procter View Post
    Here's an easy solution if you're worried about stress on your bar:
    Mar 2013
    any lock on grip with open ends. you will probably also want wider bars to comp for what the bar ends take up
  1. Looking for good bar ends/alternative grips for my MTB
    By dwagner in forum General Discussion
    Last Post: 08-22-2014, 01:02 PM
  2. Bar ends on Cannondale D2 Grips?
    By khaytsus in forum Cannondale
    Last Post: 02-16-2012, 10:29 PM
  3. what grips & bar ends on my carbon bars?
    By mat-with-one-t in forum Singlespeed
    Last Post: 11-13-2011, 05:27 PM
  4. Bars, Grips, and Bar ends
    By Alen in forum Beginner's Corner
    Last Post: 06-26-2011, 09:24 AM
  5. Ergon grips + bar ends
    By LUW in forum 29er Bikes
    Last Post: 05-20-2011, 05:03 PM
