Results 1 to 3 of 3
    Purchase help: 2001 Rocky Mountain Edge or 2004 Cannondale Jekyll 600?
    Hello, first post here.
    I am trying to decide between two used bikes. Both are barely used, the fit is perfect for both, and they are both the same price. Any help figuring the out would be helpful.
    Thanks,
    Jen
    1) Rocky Mountain Edge 2001 (either 2001 or 2002, it is all black which isnt a color listed on bikepedia)
    Bicycle Type Mountain bike, front & rear suspension
    Sugg Retail $1,745.00
    Weight Unspecified
    Sizes 16.5", 18", 19"
    Colors Blue and Black, Electric Blue and Sky White Maple Leaf Mask
    Frame & Fork
    Frame Construction TIG-welded
    Frame Tubing Material Easton RAD
    Fork Brand & Model Marzocchi Bomber Z-3 Long Travel
    Fork Material Aluminum, triple-clamp crown
    Rear Shock Fox Air Float R
    Components
    Component Group Mountain Mix
    Brakeset Magura Julie brakes, Magura Julie levers
    Shift Levers SRAM ESP 7.0
    Front Derailleur Shimano Deore, top-pull/clamp-on 31.8mm
    Rear Derailleur SRAM ESP 7.0
    Crankset Shimano Deore, 22/32/44 teeth
    Pedals Rocky Mountain Big Flats
    Bottom Bracket Sealed cartridge
    BB Shell Width Unspecified
    Rear Cogs 9-speed
    Chain SRAM, 1/2 x 3/32"
    Seatpost Rocky Mountain, 26.8mm diameter
    Saddle Selle Italia Onda
    Handlebar Rocky Mountain DH Riser
    Handlebar Extensions Not included
    Handlebar Stem Rocky Mountain
    Headset 1 1/8" threadless Ritchey Logic
    Wheels
    Hubs Rocky Mountain Disk
    Rims Sun Rims Rhyno Lite
    Tires Maxxis Mobster
    Spoke Brand DT stainless steel
    Spoke Nipples Unspecified
    2) Cannondale 2004 Jekyll 600 (no disc):
    Sugg Retail $1,249.99
    Weight Unspecified
    Sizes Large, medium, small, xlarge
    Colors Black, Red
    Frame & Fork
    Frame Tubing Material 6013 T6 aluminum
    Fork Brand & Model Answer Manitou Black Elite
    Fork Material Aluminum/magnesium, single crown
    Rear Shock Fox Float RL with ProPedal
    Components
    Brakeset Cannondale Fire brakes, Cannondale Fire levers
    Shift Levers Shimano Deore RapidFire SL
    Front Derailleur Shimano Deore LX
    Rear Derailleur Shimano Deore XT
    Crankset TruVativ Five D, 22/32/44 teeth
    Pedals Cannondale clipless
    Bottom Bracket TruVativ ISIS Drive
    Rear Cogs 9-speed, 11 - 34 teeth
    Chain 1/2 x 3/32"
    Seatpost Aluminum micro-adjust
    Saddle Fi'zi:k Nisene, chrome-moly rails
    Handlebar Cannondale Earth
    Handlebar Stem Cannondale 3-D Forged
    Headset 1 1/8" threadless FSA Converter
    Wheels
    Hubs Cannondale Fire Disc
    Rims Mavic XM 117, 32-hole
    Tires 26 x 2.00" Hutchinson Scorpion
    Spoke Brand DT stainless steel, double-butted
    Former Bike Wrench
    You don't mention what kind of riding your doing. The Edge is a very solid AM bike capable of some pretty rough trails. The Jekyll is more of an XC or Trail bike...lighter frame with a lighter wheelset.
    T.W.O.
    Reputation: mimi1885's Avatar
    I'd get the Jekyll, it newer year and has the adjustable geometry, without changing travel. solid single pivot design. I had one love it.
