• 08-09-2012
    Slyp Dawg
    old FS XC frame for grass slalom/pump track bike?
    I've got an old ('06) GT I-Drive 4 frame, and after giving grass slalom a try a few weekends ago on a buddy's P bike (and subsequently crashing and breaking my clavicle/concussing myself), I decided to try and repurpose my old bike as a grass slalom/pumptrack bike. I know it isnt a typical (or recommended) use of an XC frame, but as a race-only/very-limited-airtime (>1', smooth transitions, etc) bike, would it likely be ok, at least until I can get a proper 4x/slalom type bike?
  • 08-10-2012
    mimi1885
    Yeah, sounds like a fun bike. Are you running single ring in the front?
  • 08-10-2012
    Slyp Dawg
    I was going to run it singlespeed to save weight and complexity and cost (one less shifter/derailleur to buy and set up)
  • 08-10-2012
    mountainbiker24
    As long as the jumps aren't massive and have good transitions (which you actually land on), the bike should be good for a little while. Just be smooth!
    However, you might be better off just selling the frame for a couple hundred bucks and buying a proper hardtail dj frame. Shouldn't cost any more, and you won't have to worry about snapping your frame.
  • 08-14-2012
    warrior737
    I have a similar bike i am intrested in trying to build up for aggressive trail riding and jumping. The bike was free . But before I go crazy on it i want to know if its worth it. Or should i go buy a new bike? Any advice would be great.
  • 08-14-2012
    mimi1885
    I guess, define aggressive trail riding. OP is using his as a slalom and pump track bike no hard landing I think it would do the job.
    Rough trail and aggressive riding may exceed its limit.
    Sent from my iPhone 4s using Tapatalk
  • 08-14-2012
    NEPMTBA
    Always a good project, one to use what you have and it will teach you the pluses and minuses of the ride... go for it!
  • 08-15-2012
    warrior737
    :DSlightly Defined.
  • 08-15-2012
    Delph
    You should consider to change the fork in the first place :) Old judy with elastomer should not be treated with that ammount of air :D
  • 08-15-2012
    warrior737
    I have a set of 140mm deuces but they dont fit the headset 1-1/8 on bike / 1.5" steerer on forks. I want to press out the steerer and cromoly weld in a new 1 1/8" steerer kit in the crown. Im worried about over heading the shocks.:confused: I was thinking about dismanteling them first.Before I weld the new steerer into the crown. Almost the same as a kit for a lefty fork headset conversion. My friend says its do able but its probably not the safety.:nono: Im a good fabricator and mechanically inclined so i think its not out of the question.:thumbsup: Besides I would trust a proper weld before a cryo press fit any day. I also want to upgrade the raer shock but I'm unsure on what to buy? Do i judge it on shock length from eyelet to eyelet and coil size? Any help would be great. I wanted to start a thread and I just didn't have enough posts yet.
