Results 1 to 5 of 5
    Norco Fluid lt 3 or Spec. Pitch Pro??
    I'm currently looking for a solid All mountain bike (I live for the descent...but I'm usually getting up there on my own so i need to be able to climb). Initially i was looking at the Pitch comp, $1900 seemed like a great deal, but I've read reviews that said it's smarter to put in the extra cash and opt for the pro...but if i was going to spend $2300 on a bike this opened up other options, such as the norco fluid. I have found many good reviews on the pitch but i haven't really been able to find much on the Fluid lt 3 2008. Can anyone give me some advice on what might be the best option? The norco seems to have more front susp. travel, but i think the shocks on the pitch may have more settings. I've also read the rear shock on the fluid (Fox DHX-AIR 3.0) may have a problem with getting stuck down...I don't know if this would be a problem with me as I'm a small/light guy.
    Any other suggestions would be appreciated, I've also taken a look at the rocky mountain slayer sxc 30 (can't find pricing but i think it's above my price range), and the norco six three(i think this bike might be too burly for uphill rides).
    I'm UTarded
    Reputation: powderboy's Avatar
    I've ridden both bikes and reviewed both of them:
    Fluid LT3
    http://www.feedthehabit.com/mountain...n-bike-review/
    Specialized Pitch Pro
    http://www.feedthehabit.com/mountain...-quick-review/
    Both bikes are great all-around trailbikes, but each has some drawbacks. I haven't ridden them side-by-side (I rode the Pitch last fall and have the Fluid LT3 currently), so it's hard to do direct comparisons, but here are some thoughts.
    • The Pitch seems to be more on the XC-ish side compared to the LT3
    • The LT3 isn't as capable of a climber as the Pitch
    • Both are horst links... they will both perform well under all conditions
    • I don't know the spec on the Pitch Comp, but the Pitch Pro seems fairly solid... maybe a hair better than the LT3
    • The Marzocchi 55R is great going down, but it lacks travel adjustment, so it does wander on tight, steep stuff
    • Norco's are less common here in the States... and they are great bikes.
    It's all subjective... but, both bikes are capable and should be fun all-around bikes.
    Thanks, i appreciate the info! I actually just picked up the fluid lt3 a day ago but it's good to hear it would have been a safe bet to go either way! I'm a bit worried that the lack of shock adjustment and weight might give me some issues on ascents, but I'm hoping the bikes performance on decents will make up for it. I can't weight to get the bike out on the trails!
    Tire Geek O_o
    Reputation: cesalec's Avatar
    Hi gothMogs_Fury,
    would you post your impressions on your new bike??
    it would be great!
    Here's a link to a review of the Fluid LT1 and 2.
    http://dev.nsmb.com/page/s/2607
    I personally ride a regular fluid and have nothing but good things to say about the bike.
