    Aug 2014
    Need some advice - 2008 Trek Fuel EX8
    Hey everyone! Need a little advice about my new purchase. Just picked up a 2008 Trek Fuel EX8.
    Geezus, what a pain this thing has been. Should have known something was wrong when the guy wouldn't let me come to his house. Lesson learned: I won't buy another used bike without taking it on a trail first. It was basically rigged enough to make a sell.
    The first big ride I knew I had problems. Chain slipping badly on climbs, front brake wasn't working correctly, and the rear was making a ton of creaking noise. New cassette/chain, front caliper rebuild kit, and new bearings in the rear...after a few weeks of waiting on parts, I finally got to take my bike out and everything seems to be great now. Except for my confidence in the bike. See below:
    Long story short, while I was trying to hunt the chain slip issue I noticed a huge gash mark on the inside of the triangle. A couple of cm's deep in the aluminum. Looks like it's been rubbed by tire over a period of time. Haven't figured out how that happened yet. Pretty sure the previous owner must have had a different wheelset.
    Anywho...I've been on the hunt for a new triangle to replace it because I'm picky about my stuff. Didn't take me long to stumble across multiple threads about people cracking/breaking the rear triangle on Trek Fuels.
    I'm kind of bummed now. I feel like it's a matter of time before I have the same thing happen. Seems like it's super common.
    What makes me feel a little better is it seems people have had some good luck by working with their LBS on getting a replacement under warranty. Apparently the pre-2010 stuff had lifetime warranties? That's for the original owner, of course.
    Thoughts?
    T.W.O.
    Reputation: mimi1885's Avatar
    Holy crap!, sorry to hear that you got a bum deal. Got pic?
    Aug 2014
    Just finished up a nice weekend of riding. Put about 20 miles worth of rough terrain on it with only minor hiccups.
    Here are some pics of the bike with the damage I mentioned above:
    Tried to get the best pics I could. The gash is about 1-2mm deep. The edge of the tire lines up with it perfectly. I was doing some pretty fast downhill today and I noticed on hard right turns I was hearing some rubbing...I'm assuming in this spot since I don't see any other places.
    I can get the tire to hit the frame if I put some pretty good pressure on it by hand. Should there be any give whatsoever?
    I also have some popping noise coming from the Evo link. I greased the bearings but it's probably time for a change since I noticed the upper two had some catches in them. Ugh...
    Aug 2014
    Figured out the rubbing issue. Previous owner was running a 2.35 on the back. Not enough clearance on hard turns. Sheeesh.
  1. how much for 2008 trek fuel ex8?
    By zskolb in forum General Discussion
    Last Post: 05-31-2012, 10:24 PM
  2. 2008 trek fuel ex-7
    By henry9419 in forum Trek
    Last Post: 05-18-2012, 05:34 AM
  3. 2011 Trek Fuel EX5 or 2008 Trek Fuel EX9
    By tavorh1 in forum Trek
    Last Post: 11-08-2011, 06:07 PM
  4. 2008 trek fuel ex 8
    By locote in forum Bike and Frame discussion
    Last Post: 09-08-2011, 11:35 AM
  5. 2008 Trek Fuel Ex 9 Good Deal?
    By mad6350 in forum General Discussion
    Last Post: 04-02-2011, 03:16 PM
