Need Info on gary fisher GED
Hey all! Just found a 2005 gary fisher GED for $500. its a 17.5'' frame.
i'm 6'0 tall and am just getting back in to mountain biking. I have test driven the bike and it feels OK even though my LBS says i should be using a bigger frame (19'').
The bike is all stock and is described as a dirt jumping bike. i was wondering:
a) could i use this bike on some XC trails
b) what modifications have to be made in order to do so
c) are the components good.
it seems like a good deal. please help.
check it out:
http://bikepedia.com/QuickBike/BikeS...=GED&Type=bike
ride like you stole it
The frames fine for riding xc but I don't know if it is for you cause its so small, I have the same frame in the 19" and am 6' tall and it sometimes feels a little cramped on longer rides.
If you want to do it a longer stem could help. It all depends on what you doing, I ride mine everywhere (xc, dirt jumps, and light freeride) so its good for me but if I were to start riding more xc then I do know I would definitely be lusting after an xc bike.
As the bike sits its pretty much a do it all hardtail with decent components.
I lubed my disc brakes because they squeaked.
Man was that fun to work out
There's no app for this.
It might fit if
you have longer legs and a shorter torso. The fit to ensure is correct is the top tube length, and the 17.5" GF-GED is 23.6" long. Your total height means little, it's the cockpit that has to fit.
Here's the GF archive. http://fisherbikes.com/bike/archivemodel/133
And would you buy shoes that 'almost' fit if they were a deal? Can you feel the pain?
It's no deal if the fit is wrong. It's then an expensive dust collector.
Jim
- You may not post replies
- You may not edit your posts
Forum Rules
