Results 1 to 23 of 23
    May 2013
    Need Help Identifying this bike.
    Hi,
    I'm a really beginner from Sri Lanka and i recently started riding. I don't really do mountain biking but i really love bikes and i only use my bike daily to go to gym which is around 6 miles away from my home.
    I recently purchased this bike from local dealer which is a used bike for my daily work which was in recently good condition. In detail, clearly the frame has been re-painted and original decals has been removed and installed with seems to be aftermarket decals. most of the parts are from shimano deore XT series and it had Da bomb bazooka carbon fiber handle bar, crank is Hussefelt and front shock is and RST probably a Gila. its a dual disc bike with shimano disc rotors. The serial number resides at the down side of the bottom bracket CSC2002151. The frame is somewhat similar to schwinn mesa series frame but i couldn't track the serial number for schwinn or any other brand. The bike itself is really featherweight and well equipped. The reason I'm posting this is to clarify whether this is a branded bike or just a bike made in China or Taiwan. The pics are attached below. If someone could identify the frame or model that would be really helpful.
    Need Help Identifying this bike.-img-20130511-00045.jpgNeed Help Identifying this bike.-img-20130511-00031.jpgNeed Help Identifying this bike.-img-20130511-00032.jpgNeed Help Identifying this bike.-img-20130511-00033.jpgNeed Help Identifying this bike.-img-20130511-00034.jpgNeed Help Identifying this bike.-img-20130511-00035.jpgNeed Help Identifying this bike.-img-20130511-00036.jpgNeed Help Identifying this bike.-img-20130511-00037.jpgNeed Help Identifying this bike.-img-20130511-00038.jpgNeed Help Identifying this bike.-img-20130511-00039.jpgNeed Help Identifying this bike.-img-20130511-00040.jpgNeed Help Identifying this bike.-img-20130511-00041.jpgNeed Help Identifying this bike.-img-20130511-00042.jpgNeed Help Identifying this bike.-img-20130511-00043.jpgNeed Help Identifying this bike.-img-20130511-00044.jpg
    Reputation: masterofnone's Avatar
    Wow, it looks like that bike shop was looking to clear off some shelves, quite an interesting collection of parts.
    May 2013
    Quote Originally Posted by masterofnone View Post
    any idea about the model or frame??
    That real triangle looks familiar, but no,sorry.
    B A N N E D
    Branded bike frames (even the good ones) are mostly made in China and Taiwan.
    With the "Ala-Cart" build kits out there, ya just never know. Most everything there is recognizable, and possibly could be dated according to the mix but even at that, You'll prolly find out when someone recognizes it as exactly the same as his "?????????"
    Titanium junkie
    Reputation: Loudviking's Avatar
    Oct 2011
    It's a Schwinn, probably a Moab....
    Schwinn used that seat stay for years.
    Climb into the sky, never wonder why - Tailgunner
    You're a Tailgunner
    May 2013
    Quote Originally Posted by Loudviking View Post
    that is also what i thought
    B A N N E D
    What Schwinn had drop outs like those ?
    Schwinn wasn't the only brand that used the wishbone seat stay design.
    Titanium junkie
    Oct 2011
    You are correct, come to think of it Schwinn had that chain stay that looked bent.
    Ok, I give, don't know what it is.......
    You're a Tailgunner
    B A N N E D
    Found some photos of a Schwinn Frontier with the same dropouts.
    May 2013
    Quote Originally Posted by cobba View Post
    they seems identical :O which year is this, GSD or GSX??
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    It is a frankenbike, for sure. The levers look like older LXs, the crank arms seem to read Truvativ as well. The wheels match but the skewers don't and the red stem?
    That said it looks well put together and the cable routing is tidy. This should be a fun bike.
    I don't rattle.
    May 2013
    What is a frankenbike? Crank arms are Truvativ but crank wheels are bontrager , red stem is a Kore lite 3 i guess . previously i had 2 bikes around 4,5 years back so i sort of know about servicing, adjustments etc, so i did all the servicing and cable adjustments of this bike my self . Bike actually rides well, really smooth, no noises or what so ever after servicing. front shock has a little bit of play even i serviced and cleaned it completely. So i ordered a suntour xcr fork which is good for road usage.
    B A N N E D
    Quote Originally Posted by prabarshana View Post
    Your bike.
    A frankenbike is bike put together with all sorts of components, it's not a bike you can look up the specs on as none of the parts are original.
    Those photos were from a 2011 Frontier Elite, that year model has the brake & shifter cables on the underside of the top tube so it isn't the same year as yours.
    I would wager the highest percentage of bikes are Frankenbikes- I know mine are. That's what makes it fun looking at pics like these.
    My baby is a '95 Bontrager Racelite. Well, actually the frame, the seatbolt clamp and the anti-chainsuck plate are from the original. Everything else was added on over the years. I made some nice upgrades when it was stripped down and powdercoated in a refurbishment in 2008; carbon fiber, XTR, custom wheels, Ti bits. Sooo not a frankenbike.
    Masterofnone said: "it looks like that bike shop was looking to clear off some shelves, quite an interesting collection of parts." Sometimes these bikes are referred to as a "parts bin" bikes.
    One of my son's bikes is a true frankenbike; a seemingly disharmonious assembly of parts which makes sense only when you ride it. We just got lucky with colors.
    The Ascent is a true Frankenbike. I found the frame new,with a scratch, at the shop for $50, combined two different Bomber shocks to make one that worked, pulled a mix of components (coda, shimano, avid, cane creek) out of my parts bins and, voila! Not a bad bike. Note the yellow stem. Sold it for $250 about 11 years ago and it is still being ridden.
    Congrats on the purchase but, please, do me a favor and change that stem color.
    Attached Thumbnails Attached Thumbnails Need Help Identifying this bike.-bontie852.jpg
    I don't rattle.
    May 2013
    Smile
    Quote Originally Posted by Berkeley Mike View Post
    Thanks and sorry for the long delay to reply. I actually change the stem to raceface forged one black. And found out ant*les is a japanese bike brand after a much research Its known as 'antales' which is a very rare bike brand outside the japan. Y'sRoad100yrs history?Y'sRoad. Now the brand is renamed as ant*res which is mainly focus on road bikes.ANTARES | Y's Collection?????????? . http://www.brandbicycle.jp/YS%20ANTARES1_R.JPG Anyway, I also received a 2005 model gt avalanche 0.5 frame which was manufactured in 2010 which i was hoping to swap the parts from antales to it. Any way it has received some new parts including front fork, shimano 10 speed cassette, deore front derailer and some small upgrades. Now its been stripped down to polish the bare metal since i dont like the orange with lot of touch-ups
    B A N N E D
    That doesn't sound right.
    May 2013
    well u are right i actually clarified with a japanese guy working with us today. it actually says registered in 2010. So my bad
    May 2013
    Hope This is the current state of the bike :)
    Need Help Identifying this bike.-img-20131013-00067.jpgNeed Help Identifying this bike.-img-20131013-00068.jpgNeed Help Identifying this bike.-img-20131018-00078.jpg
    Nice job dude!
    I don't rattle.
    May 2013
  1. Help identifying bike
    By Manny34 in forum Specialized
    Last Post: 03-25-2013, 06:43 AM
  2. Help Identifying the bike
    By kokot72 in forum 29er Bikes
    Last Post: 01-19-2012, 06:54 AM
  3. Need help identifying bike
    By saiha in forum Beginner's Corner
    Last Post: 04-28-2011, 07:39 PM
  4. help identifying this bike
    Last Post: 04-16-2011, 05:59 PM
  5. Need help identifying this bike
    By MXRider72 in forum Urban/DJ/Park
    Last Post: 03-09-2011, 07:38 PM
