Results 1 to 2 of 2
    New question here. Need Help!!!!!!!!!!!!
    Ok I have this gray fisher opie Size is extra small. I am thinking of putting a new frame on it. A Kona shred frame on it. i'm pretty sure i can put on everything but one thing. the crank set...... Gray fisher comes with Suntour CW9-XCC and Shred uses a FSA Step Up ISIS Crank. So do u think they the Suntour CW9-XCC can fit in to the Shred's frame?
    dru
    dru is offline
    Can't see why not. Almost all frames use 68mm BB shells these days, and the rest use 73. The BB manufacturers often use shims to accommodate this difference.
    Drew
    occasional cyclist
