My Baby: My custom Giant Revel. Love/Hate? Share your projects!
I bought a Giant Revel 2 off a friend for 150 bucks (he bought it for 300 and immediately decided that he wanted a FS). I was looking for a HT 26er project, and here it was. As you all know, the stock components were terrible and the bike was quite a load (I'm not sure of the stock weight, but it had to be 35lbs). So I spent about 4 months compiling new parts via cheap internet sales (I was determined to do this on a budget...I'm a grad student), and here is my final product: Every single component has been upgraded other than the headset.
I've got the weight down to 23 pounds, which has made riding it lot of fun. Also, this is my first time going 1x9 and I LOVE it!
Happy for ya! Any pictures?
Thanks! Just posting them, the upload is going slow for me.
looks like a great ride... but a few tidbits...
it appears your chain is to long... Park Tool Co. » ParkTool Blog » Chain Length Sizing
and your cockpit looks like it's pushed to far forward... look into measuring for K.O.P.s... it'll more then likely (unless you've got a weirdly short femur) push your saddle back a bit... then a shorter stem will keep the cockpit length the same... also your saddle rails appear to be bent... part of it being so far forward (the same thing can happen to it if it's to far back)
but in the end... enjoy it
- Trek Sawyer - 1/2 fat 29er
- Surly 1x1 - geared 700c pavement pounder
Thanks for the response, Donalson. I appreciate the feedback. I am looking into a shorter stem...any recommendations for a shorter, decently priced, low rise stem?
How is something like the Easton Havoc?
Easton Havoc Stem '09 > Components > Handlebars and Stems > Stems | Jenson USA Online Bike Shop
it looks to me as the forks are the wrong way round??
my mistake no there not
Hey Goldie, Manitou forks and ive seen some dt swiss forks that use a reverse arch. Looking at it takes some getting used to, but I can not believe how sweet this fork is for the price.
Since the only one showing available is the 80mm, I would say that it's probably a good starting point. You really do need to get that saddle centered better on the rails and you could probably benefit from tilting it so that the saddle is level (not nose up like currently).
Actually after you posted your first response to me, I went and fixed the saddle. It is perfectly level and centered (way better, btw, so thank you for that).
Because of the price, I just ordered this from Jensonusa:
Race Face Ride Stem Oe '12 > Components > Handlebars and Stems > Stems | Jenson USA Online Bike Shop
in the 60mm, which is going to be a huge difference from my current 110mm stem.
Thanks again for all of the advice
I like the handlebars and grips. My favorite grips.
I love the grips too. Whenever I think I should go with different grips, I just cant. too comfortable/cheap (and more durable than I thought)
Nice ride! I too used the oury grips on my last bike. My new bike has some ergon type grips that aren't as large in diameter that I really like now. Post some new pics of that 60mm stem on your revel.
Sent from my cm_tenderloin using Tapatalk 2
1x9 just one step closer to SS. At least it was for me. Nice ride.
Another Oury grip fan here. And yeah love the Giant bikes. It's fun doing bikes up isn't it!
Looking at photos of this build I've noticed a problem, the pad wear on the rotors braking track indicate that there is a brake alignment problem.
A closer look and I see Avid CPS washers, the Shimano brakes you have were never meant to have these fitted.
By fitting the CPS washers you are effectively moving the brake calipers outwards away from the axle about 5mm or so, the first result of this is that you will have less braking power because there will be a section of the pads which overhangs the outside edge of the rotor and doesn't contact it.
Second thing the overhanging pads will lead to another problem as the sections of the pads that contact the rotor wear down, there will be an unworn section of the pads which overhangs the rotor. One day when you squeeze the brake lever, instead of the pads pushing against the rotor, the two unworn sections of pad will be pushing against themselves. The result of this will basically be a loss of brake power which could end up being messy.
Basically you need to get rid of those CPS washers before a disaster happens.
how did you like the giant in stock form?
im getting into biking and considering a revel 1 but unsure!
Hey zkid,
If you think you are going to enjoy it and keep on biking, then it is definitely a good starter bike. I would recommend the Revel 1 or 0 for sure over the Revel 2 (because when you want to upgrade the components, those versions start with better quality ones).
But if you think you will enjoy it and stick with it, you might want to look into something a bit higher end, depending on price range. I really like my bike, but my brother recently got a better bike, a Scott Comp 29er, and I am very jealous, especially at the price he got it for: 750 bucks.
But I will say this: The Revel 0 and even the Revel 1 comes with some pretty nice stock components...things you wont need to be upgrading and way better than the Revel 2. I would take a good look at your budget and see what you can afford, because you will see if you look around these boards: it is easy to get bit by the upgrade bug if you have cheap parts, then you end up spending a good amount on parts...but its fun!
I definitely endorse the Revel Frame, its quite strong and has taken a beating. Keep me updated on what you go with!
Also, check around the bike shops to see which shops are more of a well-run pro shop with good mechanics, as opposed to a franchise or chain. I made the mistake of going to a place with crap mechanics that just sell bikes and dont know too much about them.
Have you still got those Avid CPS washers on the brakes ?
Cobba! I am sorry that I never responded...I actually took it in to my LBS and they removed them. I bought the brakes on ebay and they said that those washers must have been put on by the seller. Thanks so much, and I respect/admire your keen eye!
That's a sweet bike. The Revel 2 is on my short list.
This has to be the most decked out Revel 2 i have ever seen. I work at a bike shop that sells Trek and Giant and at the revel price level i always push them they really are great bikes for the money. The Trek 3500 which is the same price is a joke compared to this bike component and frame wise.
That is awesome you got it down to 23 pounds, I weighed a stock revel 2 the other day and was shocked it tipped the scale at 32 pounds. I bet it rides like a completely different bike, although it basically is. Correct me if i am wrong but i do not see one stock component..haha
Thanks Tninl, I have also fixed some of the issues pointed out in this forum (shorter stem especially). I built it up on the cheap with internet deals, to be honest. Also, I test-rode some trek 3500s, and I did not like the feel of it at all!
And there is only one more stock component left, but you can't see it... the headset--though I did change the bearing cups and grease them up.
Can you answer a question that I have asked lots of people, and gotten no answers: what the heck type of headsets does Giant use??
On the Giant Revel bicycles they use a semi integrated headset, basically it does have the bearing races pressed in but they are not visible like the traditional press in headsets. This gives a cleaner look IMO compared to the traditional press in headsets.
The downfall is there are not many options for aftermarket headsets, like a cartridge bearing set up. At least not any that i know of i could be wrong though.
I can ask my giant rep next time he comes in and let you know what he comes up with. I have noticed trek doing this on several models too so I am sure its just a matter of time before they are readily available.
looks like a zero stack headset... should be plenty of options; like the Cane Creek ZS-3
- You may not post replies
- You may not edit your posts
Forum Rules
