Results 1 to 15 of 15
    Reputation: johnnerzz's Avatar
    Dec 2013
    New question here. ..A long shot. Could anybody from the US help?
    Hi guys,
    I read this forum post after converting to a single chainring up-front on my Cannondale Trail SL4 and came up against the same problem of the cable-guide snapping off because it is pressed in with a weak plastic nub, rather than being tapped in:
    When Cannondale's Bottom Bracket Cable Guide Sucks... MAKE YOUR OWN!
    The issue that I have is that to follow what this guy has done (ideal), I can't purchase the required thread insert from McMaster-Carr because they won't ship to the UK because of US export regulations.
    I have been in contact with UK businesses who supply brass inserts and they don't supply the kind of above insert which is a critical dimension to the 1/4" hole on the BB of the bike. They say it's an extremely low performance design of insert and not something the industry uses. To manufacture an insert to the specifications required, I would need to order a minimum volume of 10,000 units... (no thanks).
    I have tried to contact the guy who created the DIY tutorial a couple months back, but his account appears to be dormant.
    It's a longer shot, but I'm wondering how possible it would be if anyone from the US could take an order of these brass inserts from McMaster-Carr and send them to me here in the UK at my expense? I was hoping the guy who did the DIY thread could have made me one
    If only he knew I was trying to contact him!
    This has been really frustrating, as it's such a simple and ingenious idea of making a solid cable guide that doesn't snap on the SLs. Unless anybody else has any other ideas?
    Thanks, J!
    Looks like a pack of 25 is $7.83. I can order a pack and ship it to you. Why don't you contact me at gdkeys@gmail.com and we can work out particulars.
    Reputation: time229er's Avatar
    Oct 2013
    here is another option...
    I am sure though you could find locally...ask for "Nut-Zert"...do you have access to Grainger Supply as they could supply!
    2014 Nail Trail 29...
    Oct 2013
    you might try this too...
    according to Grainger's website, this outfit is a "Grainger Authorized Reseller"...and they are located in London. Phone listed on their website is +44 207 793 38 38
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Re: ..A long shot. Could anybody from the US help?
    Dec 2013
    The reason why the thread insert is a critical dimension is because the hole isn't completely hollow. There's between, or just under 6 or 5mm's in depth before it hits the axle. I believe punching a rivet or any sized insert into the hole wouldn't fit accurately.
    Oct 2013
    you are in virgin territory...good luck
    Dec 2013
    No it's already been done. I'm following this DIY: When Cannondale's Bottom Bracket Cable Guide Sucks... MAKE YOUR OWN!
    Oct 2013
    Quote Originally Posted by gdkeys View Post
    looks like you have a viable option...what more are you needing
    Dec 2013
    Good job!
    Once GDkeys gets the thread inserts out to me (I can't thank him enough for offering to help), I will have to find a way to fabricate a similar, durable plastic-guide as done in the DIY thread - it looks really strong, and I like how he applied a cover to it too. Or, purchase a Cannondale Synapse cable-guide which is threaded (I don't understand why they didn't just do this for the Trail SL models anyway, instead of installing a snappable plastic nub...), but I need to find out the size of the thread against the insert diameter.
    Oct 2013
    personally, I don't believe I could own a bike that the mgf routed the cables/hoses under the BB...accident just waiting to happen.
    Dec 2010
    Quote Originally Posted by time229er View Post
    Why do you say that? It's been done for years and is still being done today.
    Oct 2013
    ^^^^ that certainly don't make it right...
    Riding a bike could be considered an accident waiting to happen... but most of us here still do it.
    Oct 2013
    Quote Originally Posted by sasquatch rides a SS View Post
    well then make sure you check the PF30 box too, that way while you repairing a bashed cable under the BB you can attempt to remedy that creaking noise since they are both in same neighborhood.
  1. Long shot: Lost light at OP
    By floxy in forum Arizona
    Last Post: 03-08-2014, 05:41 AM
  2. long shot but...
    By EastBay_Slim in forum Knolly
    Last Post: 12-12-2012, 10:00 PM
  3. long shot, but looking for witnesses to a hit and run collision
    By LONO100 in forum California - Norcal
    Last Post: 01-20-2012, 07:54 PM
  4. Long shot... Falcon 24 Manitoba
    By yahsper in forum Endurance XC Racing
    Last Post: 01-09-2012, 01:59 PM
  5. Long Shot - Lost Keys
    By pisgahproductions in forum North & South Carolina
    Last Post: 02-21-2011, 04:45 AM
