Page 12 of 19 FirstFirst ... 2 8 9 10 11 12 13 14 15 16 ... LastLast
Results 276 to 300 of 452
  1. #276
    Not totally sold on the raw aluminum look but I can't deny its functionality.
  2. #277
    Reputation: xl_cheese's Avatar
    My previous Ventana El Patron 29er.
  3. #278
    Here it is all built up.
    And being ridden.
  4. #279
    Good bye
  5. #280
    Quote Originally Posted by xl_cheese View Post
    Nice! It looks kinda short though.
  6. #281
    Master of the Face Plant
    76 years of oxidation can be harder to get off than paint.
    http://www.nbbikes.com/
    ^^^Best Bike Shop of MTBR 2008^^^
  7. #282
    Isn't that going to rust?
  8. #283
    Quote Originally Posted by smilinsteve View Post
    No, it's aluminum. Yes they had aluminum bikes in 1936. I will oxidize if you don't polish it once in a while.
  9. #284
    Quote Originally Posted by sandmangts View Post
    That is sweet!
  10. #285
    It's going to rust. That's why it was so hard to polish.
  11. #286
    Quote Originally Posted by Mountain Cycle Shawn View Post
    Really? The first photo was taken 3 years after I built the bike. I didn't notice any rust. I know bare aluminum will oxidize if not properly cared for but I use a polish followed by an automotive polymer that creates a barrier from moisture called liquid glass. I have not had to polish it for quite a while.
  12. #287
    That's amazing those thin tubes are aluminum, from 1936!!
    That frame must be worth something.
    Great job polishing it.
    my 2 cents: aluminum doesn't rust unless you call oxidation rust, but rust normally refers to iron oxidation, not oxidation in general.
  13. #288
    no mo pics yet
  14. #289
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    How about some pictures of the dog in your avatar? I love bull breeds.
    A garage full of steel frames means happiness.
  15. #290
    CS2
    CS2 is offline
    Very nice bike. How about some history or the build specs?
  16. #291
    Oct 2007
    Aluminum can oxidize, but only iron can rust.
    2013 Santa Cruz TRc 650b
    2015 Lynskey Cooper CX
    2010 Soma Groove
    1987 Haro RS1
  17. #292
    Quote Originally Posted by CS2 View Post
    I'd like to know how that thing is held together. There are no welds visible around those lugs!
  18. #293
    Very nice
  19. #294
    The tubes are press fit into the forged pieces. It is a 1936 Wards Hawthorne Silver King. I got the frame for $100 bucks and the steerer tube was separated from the fork. This was a common issue. I milled another from a modern 1 inch steerer tube. The seat post was another challenge. It works just like a quill stem with a bolt and an expander to keep it in place. Finding an original is impossible so I made one out of a piece of aluminum rod by boring out the center and using an old quill stem wedge and bolt.
    It took lots of wet sanding down to 2000 grit to get a good base for hand polishing. The rims are vintage Araya 7x that I also polished. The front drum hub is an old Sachs and the rear coaster brake is a Morrow hub from the 40's. The cranks, truss rods, rear hub all came from an old Elgin. The stem is a Suntour, the saddle is a Brooks.
  20. #295
    nothing to see here
    Reputation: Stevob's Avatar
    Nice work! How many hours sanding & polishing to get it (just the frame) to that stage?
    I see hills.
    I want to climb them.
  21. #296
    Oct 2011
    This thread got me dialled in stripping the paint of my (modest) bike.
    My first attempt at doing something like this,most of the work done using chemical paint stripper and steel wool except for the dropout area where had to use a drill with steel brush.
    Have one question thought: I tried to use the woven cleaner trick to strip the anodized from an aluminium seatpost and it works reasonably well but the laser etched logos and lettering remain on bare aluminium, although not so much visible cant seem to brush them off. How deep can this laser etched things remain on aluminium?
    Attached Thumbnails Attached Thumbnails Let's see your raw aluminium!-rr5i.jpg
  22. #297
    Reputation: marpilli's Avatar
    FMCurto, your bike looks great!
    I don't have the experience to answer your question about removing the laser etching, though.
  23. #298
    Sep 2012
    sandman, that is the most beautiful bike I have ever seen. I really have to have one!
  24. #299
    Quote Originally Posted by Mostly Broken View Post
    They come up on ebay and craigslist every now and then. Frames usually go for about $100-$200 bucks. My total investment on that bike was only $700 dollars. I have had offers on it up to $2000.
  25. #300
    Nov 2012
    good aluminium frames
