    Khs Fr 1500 - 2000' 03
    hi guys!!!
    Does anybody knows the difference between the KHS fr1500 and fr2000 frame, of course, apart the rear shock.
    I would aprecciate if you could help me with this doubt.
    Reputation: nwmtb's Avatar
    identical
    Quote Originally Posted by klito
    hi guys!!!
    I called a KHS inside rep and he couldn't identify any difference's, so i believe the only difference between the two were the components that each frame was spec'd with.
    I happen to have a couple of the FR2000's w/Romic in stock from an earlier KHS monthly sale, a great frame for the money.
    later, Chad
    http://redbarnbicycles.com/
    Quote Originally Posted by nwmtb
    later, Chad
    I have a FR1500 with a FR2000 rear on it....
    Chad, can you get with your KHS inside rep and find out if you can get replacement bolts and nuts for the rear shock on this bike.
    I emailed KHS and they told me to contact Fox.
    I contacted Fox, and they told me that KHS would be the source for those.
    Personally, I think the KHS rep was mistaken.
    Thanks,
    Aaron
    Quote Originally Posted by funboarder1971
    Thanks,
    Aaron
    Just to make sure, do you need the shock hardware OR are you after a pivot rebuild kit ?
    .... i won't have much trouble locating a rebuild kit for you. Feel free to contact me off board at chad@redbarnbicycles.com , i got hold of the right rep at KHS and they are available. And as for the shock hardware (bolts and aluminum spacers/sleeves) the rep was right we need to get those from FOX, or another distributor assuming you are running a Fox shock.
    later, Chad
  1. Khs Fr 1500 - 2000' 03
    By klito in forum Vintage, Retro, Classic
    Last Post: 06-23-2004, 12:32 PM
  2. Opinions on the KHS FR frames?
    By jts628 in forum Downhill - Freeride
    Last Post: 05-13-2004, 02:09 PM
  3. How is 03 Z1 FR held together?
    By two6's in forum Shocks and Suspension
    Last Post: 04-10-2004, 09:43 PM
  4. '03 Z1 FR owners
    By miufahkiu in forum Shocks and Suspension
    Last Post: 03-22-2004, 06:36 PM
  5. '03 Z1 FR preload knobs
    Last Post: 03-18-2004, 08:20 PM
