Results 1 to 7 of 7
    Aug 2014
    Ice Tech Rotor and caliper question.
    Good day guys! I'm wondering if it's okay to use non finned brake pads with an Ice tech Rotor using the SLX brake ice tech. Unfortunately, our LBS does not have finned brake pads available. I'm just concerned if it's compatible and if I won't be having issues in the long run. Thanks!
    B A N N E D
    Non finned pads will be fine.
    Aug 2014
    Quote Originally Posted by cobba View Post
    Thanks! Only the non finned resin pads is available at our LBS. I'm just concerned with my XT ice tech rotor.
    B A N N E D
    Quote Originally Posted by Martz69 View Post
    There's nothing to be concerned about.
    Aug 2014
    Thanks cobba!! Just need confirmation because some says that it is not advisable and could damage the rotor.
    Reputation: racebum's Avatar
    Mar 2013
    i'm using avid organics in their elixir brakes on xt ice techs, work great and don't squeal like the POS avid rotors, i know the lower end rotors mention resin only but i would take a wild guess it's the make up of the metal being softer. more aggressive pads would just waste the rotors faster
    Reputation: bgkz25's Avatar
    Dec 2013
    Yup +1 on racebum's. I as well use XT Icetech rotor with an elixir caliper system. No issues whatsoever.
  1. Help: XT caliper-rotor alignment
    By murphyo7 in forum Brake Time
    Last Post: 11-10-2013, 05:56 AM
  2. Xtr ice tech rotor question
    By Freeride4ever in forum General Discussion
    Last Post: 09-30-2013, 08:16 AM
  3. Avid HS-1 Rotor with BB7 Caliper?
    By magnato1 in forum Brake Time
    Last Post: 05-01-2013, 09:13 AM
  4. Hope Tech IS Caliper Adapter
    By ssrmr2 in forum Brake Time
    Last Post: 06-25-2012, 02:38 PM
  5. Caliper and rotor are too close together
    By DarkFly3r in forum Brake Time
    Last Post: 04-30-2011, 05:43 PM
