    Reputation: mikeaj92's Avatar
    How to fix screw that broke off in frame
    In my aluminum frame, where my water bottle cage is, the stock screw was no long enough to go through water bottle holder, and through my mini tire pump. It only grabbed a few threads.
    After a while I guess it broke off. I got a longer screw, but it won't go past the same threads, and then got stuck, and the "nut plate" in the frame started to turn, and then with a tiny pull, it all came out.
    Now I have a .25" hole and no threads, or any good metal to tap into.
    any ideas how to fix??
    Only one way down.
    You need your LBS to install a new metric nutsert, should take them no more 5 minutes to install.
    You need a Riv-nut tool like this, or you can just look for a tutorial on how to install them DYI on the park tool site..
    Oh wow. I must have drew a blank. As an aircraft mechanic, I know all about rivnuts. I just didn't make the connection. I'll find a pair at work in the AM.
    thanks.
    Only one way down.
  1. Broke my frame today, new bike or frame? What size?
    By JFD27 in forum Bike and Frame discussion
    Last Post: 11-08-2013, 11:05 AM
  2. BROKE my frame. What does it mean?
    By Jowsteen in forum Clydesdales/Tall Riders
    Last Post: 05-31-2013, 06:06 PM
  3. XX1 Derailleur screw broke.
    By Vegard in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-29-2013, 07:03 AM
  4. Broke my 575 frame
    By Doba in forum Yeti
    Last Post: 12-30-2011, 10:01 AM
  5. 07 stumpjumper headset screw broke off!
    By singletrkmind in forum Specialized
    Last Post: 03-02-2011, 09:41 AM
