Results 1 to 5 of 5
    Handle bar fitment help.
    Hi,
    So my frame is an xl size I'm 6' 3". Moved my forks from one frame to this one the steerer tube is now on the short side so the stem and bars are slammed. The stance is just to aggressive for me arse up nose down. I get an over the bars feeling on the flat. I've just put on a cheap stem riser to allow me to play with the height of the bars to see if I like the higher bar position. My question is. Once I find a nice height and remove the stem riser. How do I calculate what height of riser bar I need to get the same height?
    Joel
    Follow me on Twitter @OnOneCarbon456
    Hi I'am an On-One Carbon 456 mountain bike, follow me to find out what i get up to...
    Dec 2010
    Measure how much higher your bars are where you want them vs. where they are in the slammed position and get the appropriate stem and handlebar to get your bars back to that height.
    Happy Trails
    Reputation: Scott In MD's Avatar
    Use an online stem calculator to compare the rise (height) and run (length) of one stem compared to another. You will enter in the stem angle and length. Also, you could simply use a riser handle bar. If you had a flat bar before, there are a lot of 20, 30, and 40mm riser bars out there. I use an Easton XC70 riser with 40mm or rise and it works great.
    Oct 2013
    Bicyclochondriac.
    Why not stick with the riser stem?
    Anyway, if you do want to go with a riser, those online calculators are a good way to know what you will need with a different stem (in this case I assume your original stem).
    However, one problem with bar rise measurements is that companies measure them differently. Some measure the rise to the grips (in which the upsweep gets counted), some measure the added rise of the bend (rise) near the stem. I have a "flat" bar and a 20mm "riser" bar that are the same rise to the grips.
  1. Seatpost fitment
    By NightOWL in forum Yeti
    Last Post: 03-25-2013, 07:42 AM
  2. Replies: 9
    Last Post: 04-07-2012, 11:21 AM
  3. Need help with fork fitment
    By lubbockrider in forum 29er Components
    Last Post: 04-01-2012, 10:36 AM
  4. Fitment questions
    By NMloner in forum 29er Bikes
    Last Post: 09-08-2011, 07:01 AM
