Stumpjumper M4 FSR Comp. Asking price is $750, might be able to talk that down a little. here are the specs:
(Manitou Black Elite Fork & Fox Triad Rear fork). Shimano MTB Rims, and a 9 speed crankset.
Specifications:
FRAME
FSR technology, M4 Manipulated Alloy frame with TransForm Monocoque TT, sealed cartridge bearings, disc compatible, 100mm travel, replaceable derailleur hanger, two sets of water bottle bosses
REAR SHOCK
Fox Float Triad. Custom-on-the fly three position switch 1) Lockout, 2) Open, 3) ProPedal pedal assisting damping. External rebound adjust, twin sleeve design for increased volume. 6.5x1.5"
HEADSET
1 1/8" threadless, 3x sealed, black alloy cups, cartridge bearings, ultralight alloy top cap and bolt
STEM
Alloy, 4 bolt, 6 degree rise, black
HANDLEBARS
Specialized XC Low Rise bar, 2014 butted alloy, 6 degree upsweep, 8 degree backsweep, 640mm width
TAPE / GRIPS
Specialized MTB grip, black, double density Kraton
FRONT & Rear BRAKES: Disc brakes
BRAKE LEVERS
Avid SD-5, speed dial adjustment
FRONT DERAILLEUR
Shimano M-570 LX, 34.9mm clamp, bottom pull
REAR DERAILLEUR
Shimano M-952 XTR, long cage, standard spring
SHIFT LEVERS
Shimano M-570 LX
CASSETTE
Shimano HG-50 LX, 9-speed, 11x34t
CHAIN
Shimano HG-73
CRANKSET
Specialized Strongarm II, Octalink XT Spline
CHAINRINGS
44Ax32Ax22S, 4 bolt 104/64mm pattern, steel chainring bolts
BOTTOM BRACKET
Shimano ES-30 Octalink spline, 68mm shell, 118mm spindle. 50mm chainline.
PEDALS
Shimano 515 SPD & Egg Beater (includes both)
FRONT HUB
Specialized Stout, 28 hole, 9mm Skraxle
REAR HUB
Shimano, 32 hole, loose ball bearings, alloy Q/R
FRONT TIRE
Specialized Roll-X Pro 2.0, aramid bead, 120tpi
REAR TIRE
TUBES
Specialized Ultralight, presta valve
SADDLE
Specialized Body Geometry technology, hollow Cr-Mo rails
SEAT POST
2014 butted alloy, black, 30.9 x 350/400mm
SEAT BINDER
Alloy collar with Q/R, 34.9mm clamp I.D., black
Specifications:
FRAME
REAR SHOCK
HEADSET
STEM
HANDLEBARS
TAPE / GRIPS
BRAKE LEVERS
FRONT DERAILLEUR
REAR DERAILLEUR
SHIFT LEVERS
Shimano M-570 LX
CASSETTE
CHAIN
Shimano HG-73
CRANKSET
CHAINRINGS
BOTTOM BRACKET
PEDALS
FRONT HUB
REAR HUB
FRONT TIRE
REAR TIRE
TUBES
SADDLE
SEAT POST
SEAT BINDER
