Results 1 to 3 of 3
    Jan 2009
    geometry fit questions
    I am currently riding a 16" (ETT 22.7") Karate Monkey with wide, flat bars and a 100mm straight stem. I am 5'9" and it feels a bit cramped for me. I would like to get a 18" Karate Monkey (23.6"/559mm) frameset instead but somoene has offered to trade mine for a 18" Vassago Jabberwocky (ETT 24.2"/615mm).
    geometry for Jabber
    geometry for Monkey
    i am not terribly flexible and probably never will be. can I make up for the extra stretch on the Jabber with a shorter stem, or is it just going to be too long for me? I also have a Ragely Carnegie bars that seem to shorten up the reach a bit when I run them, which I don't because of the shortness of the current frame. otherwise, I could just do the trade and find out, then sell it if it doesn't work out.
    so, try the Jabber or hold out for a larger Monkey?
    *edit* also, what affect would lowering or raising the stem on my current bike have? I have a 100mm, zero degree rise stem at present with about an inch of spacers under it. could I make the front end more stable with a lower, higher, or slightly longer stem? how long is "too long" on a small frame?
    Feb 2006
    I'd compare Ebay for used Jabbers as Monkey's have good resale value and I have not checked the Jabber pricing used. That seems like a stretch for a fit given you want a upright position. Generally you want to use a stem near what the frame was designed around as it put your weight/balance in the right place for weighting the front wheel when cornering.
    Jan 2009
    price is not a concern for me since all the frames I am considering (also the On-One Inbred) are pretty darn cheap. I want to get an inexpensive frame that will handle well for me.
    edit- added another question to my original post.
  1. Replies: 6
    Last Post: 02-21-2013, 12:02 AM
  2. Replies: 1
    Last Post: 04-10-2012, 05:24 AM
  3. Karate monkey in tc?
    By TomW88 in forum Minnesota, Wisconsin
    Last Post: 05-21-2011, 04:19 PM
  4. Karate Monkey vs. Vassago Jabberwocky
    By schmed in forum Singlespeed
    Last Post: 05-18-2011, 11:10 AM
  5. The end of a Karate Monkey?
    By Kasper in forum Surly
    Last Post: 01-29-2011, 08:56 PM
