Results 1 to 3 of 3
    FS Frame With Most Tire Clearance
    I'm looking for a FS frame with plenty of tire clearance so I can stuff some wide tires in it. This of course won't approach a true fat bike, but the idea is to go as big as 2.5 or 2.6, or even better something around 3 inches. Pseudo-Fat-Bike on a budget if you will. Any suggestions on which used FS frames I should be looking for?
    I won't completely rule out a hard tail, but I'd like this bike to be my winter steed while also serving as my backup bike so I could throw on my regular tires in the event my primary rig suffers and extended repair cycle.
    Suggestions please...
    Fred
    T.W.O.
    Reputation: mimi1885's Avatar
    Check out some of the bike listed on the 650b forum. If you can see the clearance with 2.3 neomoto you should be fine. That's almost 2.75 tire clearance. I know my mojo hd clear that.
    Sent from my iPhone 4s using Tapatalk
    I actually ride 650 on my Blur LT2, and run 26" Conti Trail King 2.4's during winter (higher volume for lower PSI). I would like to go a little fatter than the 2.4's and want to have a spare bike to use from time to time when I break things or I'm doing maintenance.
    Fred
Hot Deals
Contests
Latest Mountain Bike Articles
