Results 1 to 24 of 24
Thread: Frame size
    Nov 2013
    Idea! Frame size
    Hi dear
    i am from Cambodia , nice to be part of mtbr forum . Today I have a doubt and hope everyone could help .
    I am 172cm , inside leg is 78cm
    My bike is scott scale 20 , frame size 400mm ( s ) .
    Is it too small ? Or is it just small but usable ?
    Thanks for information in advanced .
    Sergeant Spandex
    Reputation: lewisfoto's Avatar
    Nov 2013
    If I am doing the math correctly then this bike should be good for you.
    So 5.5 ft tall and riding a small? Sounds right.
    Oct 2013
    5'7"
    Quote Originally Posted by Coverdog View Post
    5'7"
    5.5 ft is approx. 5' 7".
    Nov 2013
    Quote Originally Posted by phsycle View Post
    So the right size is little bigger ? Or I could still use my current MTB ?
    Nov 2013
    Quote Originally Posted by lewisfoto View Post
    But I have to up the seat posts to hight , right ?
    Sergeant Spandex
    Nov 2013
    Quote Originally Posted by Reaksmeybora View Post
    Maybe a quick pic of your set up would help
    Nov 2013
    This is picture of MTB
    Sergeant Spandex
    Nov 2013
    That frame looks smaller than you originally posted, 400mm equals about 15.75 inches, that looks like a 13inch frame to me. However based on the picture alone I would say you need a bigger frame.
    Nov 2013
    This is 400mm as shown on frame
    Sergeant Spandex
    Nov 2013
    Ok fine, but based on how much seat post you have showing you will need a bigger bike.
    Oct 2013
    I guess if you don't count the other inch
    Happy Trails
    Reputation: Scott In MD's Avatar
    Frame size
    I'm not a bike fitter but maybe this helps: A reasonable thumb rule is that the distance from center of bottom bracket (also the center of crank) to top of your saddle should be 85% of your cycling inseam. Cycling inseam is defined as the distance from floor to your crotch, measure up up snug like a bike saddle would sit. Cycling inseam is not the inseam of your jeans .... It is a little longer.) If your saddle is set to the correct height, then your bike could be a little small, but could be fine and is certainly rideable. Many people, including me, prefer a smaller bike versus a larger bike since it is more agile and lighter. Many amateur riders like me, also prefer their handlebar grips adjusted to level with or slightly above saddle height (flat level to about 25mm higher) so you may want to swap your flat bar for a riser bar to raise your handlebars up a little, or else use a different stem to raise your bars a little. I would not be worried about the size as set up in that photo, however, as long as your saddle is raised to the correct level. It would be easier for us to give you some better advice if you could snap a photo of you on the bike, but my bike is set up similar to yours, only I have even more seat post showing than you, and I also have riser bars to raise my grips about 20mm above saddle.
    Happy Trails
    Frame size
    I think this not a valid comment. As long as the seat post is below the minimum insertion point, the seat post is fine, and the bike, set up exactly like this, would fit riders of a certain size. Lots of riders ride hard tails set up EXACTLY like this, with bars slightly lower than saddle top to get a good balanced position. I need my bars a little higher ... But this is right where a lot of flexible riders like to be. Happy trails.
    Nov 2013
    Quote Originally Posted by Scott In MD View Post
    Thanks you very much for sharing .......
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    You are fine. The "how much seat post is showing", especially considering the way the top tube slopes down, doesn't apply here.
    I don't rattle.
    Nov 2013
    Quote Originally Posted by Berkeley Mike View Post
    Thanks you sir,
    The seat post is longer , ( as shown in picture , )
    So I could up the seat post as long , By No need to change to the bigger Fram ?
    Sergeant Spandex
    Nov 2013
    Maybe but a long seatpost works as a lever so having a lot of post out will increase lateral stress which can lead to frame failure at the top of the seat tube particularly if there is only a few inches of post in the frame.
    Happy Trails
    Frame size
    Lewis - I edited my earlier reply to your post above ... At first I said your comment was stupid, but I changed it to "not valid" to give you benefit of doubt. That was a mistake ... Your comment was stupid, but this comment is almost as stupid. Actually, it's a toss-up which is more stupid.
    As long as the post is inserted past the minimum insertion line marked on the post about four inches from the bottom, the stress on the post and bike will be fine. OP is not going to crack his aluminum bike, and seat posts have massive design margin against failure. I realize you are trying to be helpful, but keep your day job, bro. If you don't believe me, ask Jaroslav....
    Sergeant Spandex
    Nov 2013
    You make a valid point about the minimum insertion line but by calling me, or anybody, "stupid" then you just make yourself look stupid. Long posts cause stress at the top of the seat tube, that is not opinion it's physics. In some causes this will cause frame failure.
    Happy Trails
    Frame size
    Lewis, peace. (Besides I didn't call you stupid. I called your post stupid.)
    Sergeant Spandex
    Nov 2013
    That is one of the most gracious things I have read on any forum in a while, so peace to you too and have a good night.
    Happy Trails
    Posrep fo' you, bro. See you out there. (Karma's probably gonna crack my post this weekend….)
  1. Broke my frame today, new bike or frame? What size?
    By JFD27 in forum Bike and Frame discussion
    Last Post: 11-08-2013, 11:05 AM
  2. Replies: 0
    Last Post: 03-06-2013, 03:22 PM
  3. wheel size and frame size
    By tosa in forum 29er Bikes
    Last Post: 01-19-2013, 04:23 PM
  4. Replies: 5
    Last Post: 09-08-2012, 07:40 AM
  5. Wheel size follows frame size
    By JonathanGennick in forum 29er Bikes
    Last Post: 09-09-2011, 02:40 PM
