Results 1 to 3 of 3
    Downsides to carbon frame?
    I'm considering a carbon frame such as Cannondale Rush 3. How would you quantify or qualify the difference in ruggedness between carbon & alumimum? One dealer said carbon is for racers (implied only) because of its delicate nature. In the event of a crash how much WORSE (if at all) is the risk of carbon frame replacement vs. aluminum? How much does this matter to me considering I've not crashed in 2-1/2 seasons of enjoying the hobby & I don't race? Does any minor crash destroy a carbon frame?
    Questions posted/recommended by moderator Clyde in quotes followed by my reply:
    What type of riding do you intend to do?
    My favorite trail has fast steep long rutted rocky hills. After 2-1/2 seasons into the hobby only one minor incident at stop, R ankle bruise; nothing at speed. But...the longer I ride the faster & braver I get.
    Do you have a preference over a hardtail or full suspension?
    FS only; see riding conditions above.
    Age, weight and height; in many instances very important for a variety of reasons.
    Born '54, that's 19, NOT 18! Making me a tender 54, 230 lbs, 6-3, in good shape. I like dowhill speed but w/ a healthy safety margin.
    What sources will you consider buying from?
    Ebay &/or forums; an XL carbon won't turn up nearby. I may pay for a pre-purchase inspection at a shop local to the seller.
    Do you want people to offer you alternative suggestions?
    I'm completely sold on 650B wheels. I will either retrofit 650Bs to a used Cannondale or get the coming '10 Jamis FS 650B due (hopefully, are you reading this Jamis?) soon.
    Former Bike Wrench
    Early carbon had some issues and that reputation seems to have followed it even 10-15 years later. Super lightweight frames...aluminium or carbon are going to be fragile. But I've been using carbon components since 2000 and did once own a carbon frame (a 3.7lbs one, not a sub 3lbs one) and they all have survived numerous impacts over the years.
    I would not hesitate to ride a reasonably built (ie not racer boy unobtanium weight frame) carbon frame myself.
    Thank you. I can't believe how rare are used XL mtn bikes/frames. I found a Rush XL frame only.
    The following are major components on my current ride:
    Shock: Fox Triad
    Fork: Fox 32 Float
    Crank: SRAM Stylo
    Shifters: SRAM X-7
    Derailleur R: SRAM X-9
    Brakelevers: Avid Juicy 5
    Handlebars: Tapered aluminum
    Derailleur F: Shimano Deora LX
    Brake calipers, rotors: Avid Juicy 5, F 203mm/R 185mm
    For a custom build: What is estimated highest price for parts equal to or better than above + all necessary unlisted parts including 650B wheel-tire set?
    Estimated highest cost for special tools for the build?
    Readers may notice I'm seeking a pessimistic/high estimate rather than the opposite.
    TIA!
    jimbo
