Results 1 to 7 of 7
    May 2013
    Custom hydraulic disc brake mounts
    Hey everyone, I had an idea about converting from v-brake to disc, and I came to the problem. There is no mounting tabs for disc brakes, so I think I could do it myself! ( rear disc brake adapter )
    I saw a video, how the guy restorated his KONA ( KONA RESTORATION - YouTube ), and thought about doing it by myself for like 3 dollars. But I just need the right measurements.
    So I drew that peas of metal on paper, so you could get the idea about what I am talking about.
    ( https://imageshack.com/scaled/large/209/alxn.jpg )
    Thanks.
    dru
    dru is offline
    You can buy that mount you've drawn up from all the tubing suppliers for dirt cheap.
    Your problem is going to be attaching it.
    If you've got a steel frame you can get it welded or brazed.
    If you've got aluminum you're gonna wreck the heat treating b/c welding.
    JSYN, I know a guy who glued a disc mount to a Girvin fork.
    It was placed in a way that braking would press the brake mount up against the back of the fork leg.
    The guy has a friend that's an engineer and works for Com Dev.
    They make satellites and have access to aerospace grade glues.
    Said engineer kinda helped out just a wee bit!
    Drew.
    occasional cyclist
    May 2013
    I have an aluminum 7005 frame.
    May 2013
    What do you mean by "gonna wreck the heat treating". Could you tell me a bit detailed please?
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    "What do you mean by "gonna wreck the heat treating". Could you tell me a bit detailed please?"
    this might help
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    May 2013
    well du-uh
    B A N N E D
    Quote Originally Posted by rushhenn View Post
    http://www.hayesdiscbrake.com/wp-con...%20QR%20IS.pdf
  1. Replies: 8
    Last Post: 03-09-2013, 12:48 AM
  2. Disc brake mounts
    By voodooridr in forum General Discussion
    Last Post: 07-04-2012, 09:06 PM
  3. Replies: 6
    Last Post: 09-12-2011, 07:24 AM
  4. Recommend a hydraulic disc brake
    By vkalia in forum General Discussion
    Last Post: 05-21-2011, 06:27 AM
  5. Hydraulic disc brake advice
    By Jordey in forum Brake Time
    Last Post: 04-07-2011, 01:08 PM
