Thread: Custom Build
    Oct 2013
    Custom Build
    I'm looking at taking my Iron Horse Warrior Pro (2006) totally to pieces and keeping nothing but the frame for a custom build, looking at doing mainly single trail and a little downhill so what do you think I should do with the old girl?
    - Marc
    29ers Forever
    Reputation: CannondaleF9's Avatar
    Nov 2012
    Fork- RockShox Revelation RCT3 130mm
    Brakes- Shimano SLX 160/180mm rotors
    Tires- Schwalbe Hans Dampf
    Wheels- DT Swiss
    Drivetrain- Shimano XT Deore Shadow Plus
    RockShox Reverb dropper seatpost.
    Everything else would be your preference- seat, pedals, stem, bars, grips.
    Oct 2013
    Quote Originally Posted by CannondaleF9 View Post
    Wheels- DT Swiss
    Approximately how much would this set me back? And The bike is completely from stock other than a pair of Hayes Hydraulic discs front and rear so all that sounds good to me, the drivetrain will be first on the list though I think.
    Reputation: coleam's Avatar
    Quote Originally Posted by MarcHamilton View Post
    That would be a pretty expensive build.
    Fork: ~$400 on ebay
    Brakes: ~$150-$200
    Tires: ~$100
    Wheels: there's a whole range, but probably around $300-$500. If you get DT Swiss, make sure you get something from the M or E lines for a wider internal width. Also look at Sin Ringle Chargers, Stans Flow (or Arch if you're light), that sort of thing.
    Drivetrain: $400 on Merlincycles.com
    Dropper post: $300
    If you're working on a budget, I'd probably lose the dropper post (or save it for later since you've already got a seatpost, presumably) and switch to a SLX drivetrain, which will be closer to $300. You aren't going to be able to get a ~130mm fork worth mentioning for much less than $400 unless you get lucky, SLX brakes are probably the best bang for your buck right now, and I wouldn't spend much less than $300 on a wheelset capable of doing trail/light DH crossover.
    Edit: you could probably stick with your current brakes. Just get them some new pads and give them a bleed. Maybe replace the seals if they need it.
  1. Custom build....
    By gregnash in forum 29er Bikes
    Last Post: 10-10-2014, 01:20 PM
  2. How did you decide on which custom build co. to go with?
    By bwheelin in forum Custom Builders & Other Manufacturers
    Last Post: 09-01-2013, 04:32 PM
  3. Custom build advice
    By DoubleHelix in forum Singlespeed
    Last Post: 05-03-2012, 08:39 AM
  4. 25.4 lb Carbine Custom Build
    By FanatikBike.com in forum Intense
    Last Post: 01-28-2012, 02:46 PM
  5. Salsa Custom Build?
    By BikeThePlanet in forum Salsa
    Last Post: 04-23-2011, 12:09 PM
