Clip less and Boots
I ride with LOOK clip less now for exercise. However, I am looking for some pedals that will be clip less and allow me to ride with hunting boots (no cleats) for when I take the bike hunting.
Suggestions?
Why not just use flat pedals if your not clipping in?
AZ - how are you so brilliant?!
Seriously, it probably takes longer to lace up boots than it does to swap pedals
Henrietta Winslow is how I'm called . Accounting is what I do . Playing badminton is the only hobby .
don't be a poacher!
What about the single-sided type?
I used the single-sided spd type for awhile. I liked being able to clip in on one side when I was wearing clipless shoes, and the flat side for when I was wearing my 5.10 Impacts.
Changing pedals doesn't take long of course, but I prefer not to have to change pedals often. In addition to a mountain bike (HT 29er) and a hybrid bike, I have 4 unicycles that I occasionally like to clip in on. Especially the 36er road unicycle with the hydraulic disc brake.
That said, I'm really loving mixing it up again by riding off-road on a mountain bike again. It is obviously a much faster experience on the bike, but I can do 20mph on my 36er going down the road. It's a single speed, but I plan on getting a Schlumpf hub next year so that I can hit 30mph on it.
Good luck with your pedal choice...
My GT Karakoram 2.0 29er (with Shimano SPD PD-M770's), 26er (with 26x3.0 Duro Wildlife Leopard tire, old-school Magura rim brake, Kris Holm dual 137/165 Moment cranks, etc), 36er (with Sinz cranks & custom cnc machined 5 hole disc brake rotor & Avid Juicy 5 brake, handlebar-drops-computer-etc.) The 36er is my charity vehicle, getting ready to do another 100 mile ride in a day on it to raise money for paralysis victims. My last 100 miler was for my paralyzed brother Gary.
Peace
Reason: add a description
Best answer What are you hunting?
I like to clip in when riding for exercise, but my hunting boots can't have cleats. I could switch pedals each time.... but wondering if there is another solution.
We are hunting deer. Since our federal gov has gated off most access roads, you can only walk or ride the X-Miles into where to hunt.
The easiest solution would be what AZMTN suggested.
Of course, you can get single-sided platform/clipless or platform clipless but then it would not be practical for your exercise ride. Most if not all Single-sided clipless pedals have balance issue which can be annoying.
Mimi,
what is the balance issue with clipless platform?
was looking at one Shimano and the Wellgo WAM-D10 Pedals, both spd. Seems this would work well.??
whatever pedal surface you are looking to use is usually the other side down (so you have to kick it back around) and that surface is sub-par to most dedicated flats
Honestly - just change pedals - It has got to be one of the (if not, THE) easiest component changes you can make.
I do it all the time.
^^^What he said It's just as quick and easy I use hex/or pedal wrench to take off and just hand tightened.
Shimano M647, M545, or M424
Time X-Roc Atac
there may be a few more but those all have what appears to be "usable" cages around the clipless parts
If it's getting really cold in winter, I combine light trekking boots (waterproof, with GoreTex built in) with some aggressively studded platform pedals. I've been using Woodman's Spiky Pro for years now, but I guess any aggressive flat pedal should do the job.
Time X-Roc Atac
I've used the above peddles with boots & they work fine. They ARE heavier then the average clip less though.
By drmajor in forum Clydesdales/Tall Riders
Last Post: 12-09-2011, 10:31 AM
By 1StuntMonkey in forum General Discussion
Last Post: 07-09-2011, 10:57 PM
By cmktech in forum Passion
Last Post: 06-12-2008, 07:30 PM
By bryanpin in forum General Discussion
Last Post: 08-13-2007, 09:58 AM
- You may not post replies
- You may not edit your posts
Forum Rules
