Results 1 to 2 of 2
    Sep 2012
    Clicking/creaking headset
    HI All,
    Not sure I've posted this in the right place so please let me know if not. Anyway, I have a 2011 camber comp and I'm getting a lot of clicking and creaking from the headset/stem area. There is no play/nothing obviously loose. I'm almost certain it is originating from the headset area, which I've always understood to be the bearing set that allows the for to swivel in the top-tube. Perhaps it just needs to be tightened up, although that's just a guess. Any suggestions?
    dru
    dru is offline
    Take off your stem and have a look at the steerer tube in case you've scored it from the HS being loose. You'll need to pull the fork out of the frame to do this. If it looks OK reassemble everything and tighten up the HS and see if the creaking goes away. The top cap tensioning bolt needs to be pretty snug. You should almost feel a bit of resistance when turning the bars left and right with the wheel off the ground.
    Drew
    occasional cyclist
  1. Nomad C creaking seatpost or headset?
    By wilsonblur in forum Santa Cruz
    Last Post: 05-25-2012, 10:13 AM
  2. Clicking/Creaking from Horst Link Area
    By ndmuscutt in forum Specialized
    Last Post: 03-26-2012, 01:15 PM
  3. Headset Creaking
    By carpy95 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-21-2012, 08:01 AM
  4. Clicking and Creaking on the Flash 29er 1 alu
    By 6guitars in forum Cannondale
    Last Post: 09-11-2011, 10:27 AM
  5. '10 RF headset clicking?
    By Noclutch in forum Gary Fisher
    Last Post: 08-28-2011, 01:06 PM
