Results 1 to 5 of 5
    Clear coating over stickers
    Hi all
    any ideas how to clear coat over stickers and when you touch it you wont feel the height of the stickers on the frame ?
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    I don't know for sure but I think it requires multiple coats.
    thanx zebrahum
    now i am doing that but there must be an easier way to do this as i believe that Cannondale doesnt waste a week just to hide the stickers under the clear coat properly
    as spraying two coats then wait 1 day another coat another day
    untill you reach some thickness above the sticker and sand down to the frame coat the re coat...
    Picture Unrelated
    Jun 2005
    Quote Originally Posted by Sagnak View Post
    thanx zebrahum
    Well Cannondale wouldn't be using a liquid paint like you're trying to do. They'll be using a clear powdercoat which goes on thicker and wouldn't require multiple coats. Or at least that's what I assume they do. I've been wrong before...
    Mar 2012
    I would recommend sanding the frame/carbon down like you were doing a normal paint job. Once you apply this sticker "recommend a die cut sticker" apply about 3 solid coats of clear then wet sand smooth
    I just did this to so,e carbon bars and they came out great
