Results 1 to 9 of 9
    Mar 2013
    cannondale flash - upgrade 26 to 29 ??
    hi to all,
    i need some information about upgrade cannondale flash.
    i have a cannondale flash carbon 3 - 2011 [26 wheels] and i want to upgrade the wheels on 29er.
    when comparing the frame of flash 26 and flash 29 at first look is the same frame.
    This upgrade is possible?
    thanks for any information.
    brg,
    perosi
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    29 inch wheels and mountain tires can only be put on a frame designed for 29 inch wheels.
    Mar 2013
    hi,
    i found a solution. Upgrade to 29er is not possible but upgrade to 650b (27,5) is possible.
    This italian video demonstrate how the guy upgrade your cannondale flash from 26 to 27.5. - La mia Cannondale Flash da 26" a 27.5" - YouTube
    brg.
    pero
    Picture Unrelated
    Jun 2005
    Well, I suppose the next question is "why?"
    Mar 2013
    why?
    if exclude all advantage of big wheels (stability on the downhill, etc.)
    because the new cannondale 29er (carbon frame) cost approx 3000 (net of discounts) upgrade for my cannondale is from 300 until 500.
    brg,
    perosi
    Picture Unrelated
    Jun 2005
    Quote Originally Posted by perosi View Post
    why?
    brg,
    perosi
    I would argue that any "benefit" from changing wheel size is negated by the fact the frame geometry is not built around that wheel and becomes a rolling compromise machine. Personally, I'd keep saving if you're set on bigger wheels.
    T.W.O.
    Reputation: mimi1885's Avatar
    Quote Originally Posted by zebrahum View Post
    ^^^This.
    The BB height would change the handling quite a bit. You'd raise the the BB almost 1" depending on the tires. Raising the BB that much would reduce "corner like it's on rail" Flash's attribute. That said if you are doing more trail riding may be it's OK. If you know what you are doing why not if not get yourself a proper 29er.
    Mar 2013
    Today I received a positive feedback from cannondale dealer.
    He told me that is possible upgrade my flash carbon 2011 on 27.5 and the total cost is around 200.
    dru
    dru is offline
    Changing to 650b will affect your bike's handling. You may or may not like what happens. It is a bit of a gamble.
    Drew
    occasional cyclist
  1. Replies: 1
    Last Post: 07-24-2012, 05:28 PM
  2. New to me cannondale flash 2!
    By galbraithrider in forum 29er Bikes
    Last Post: 05-21-2012, 07:27 PM
  3. Replies: 0
    Last Post: 05-11-2011, 04:27 AM
  4. Cannondale Flash Carbon 3 vs. Flash 1
    By mnardo72 in forum Cannondale
    Last Post: 03-08-2011, 10:57 AM
  5. Cannondale Flash Carbon 3 vs. Flash 1
    By mnardo72 in forum 29er Bikes
    Last Post: 03-05-2011, 04:51 PM
