Results 1 to 6 of 6
    Can this headset fit a 1 1/8" fork: 25.4/34.0/30.0, 36.3mm stack height?
    Aheadset, semi-cartridge, 25.4/34.0/30.0, 36.3mm stack height.
    The above are the headset model and dimensions for a 2005 Gary Fisher Utopia I'm thinking about. What I am trying to confirm is whether this headset takes a 1 1/8" steering tube?
    I think the 25.4 is the inside dimension of the headset (25.4mm = 1"). The other dimensions, I assume, relate to the cones?
    When I scouted out Bikepedia, they reference a 1 1/8" headset, and do so for this model all the way back to 2001 or so.
    If the 25.4 is the inner dimension (for the fork steer tube) and I'm SOL, could I replace the headset entirely with a new one to fit a 1 1/8" fork?
    Any help, insight here would be appreciated.
    Thanks.
    nothing to see here
    Reputation: Stevob's Avatar
    got any links to the model?
    I see hills.
    I want to climb them.
    Not really.
    Here's a link to the tech sheet I got the headset data from (http://www.vintage-trek.com/Trek-Fis...cmanualALL.pdf).
    Bikepedia was also a resource (2005 Gary Fisher Utopia - BikePedia).
    Thank for your interest.
    bike tester
    Reputation: syl3's Avatar
    Stop wasting time with tech sheets, take some calipers and measure the head tube and the fork steerer. If the HT is 34mm inside diameter you can fit a 28.6 steerer. If it's 30mm dia there is not enough place between the 1.1/8 steerer and the head tube to press a headset cup.
    Usually 1 inch steeer forks fit in 30mm frames, the only way your frame takes 1.1/8 is if Gary Fisher designed it for 1.1/8 and then slapped on a reducer headset to unload some old stock of 1" forks, this sometimes happens on lower end models in the first year when they adopt a new standard, i've seen it many times on Giant and Trek bikes.
    Haha, if it were that easy.... I don't own the bike yet. Its a Craigslist transaction and don't want to drive an hour both ways to check it out, if it won't work for me. My end game is an inexpensive disk compatible commuter/cyclocross/29er rig.
    Reputation: AnotherFolkRider's Avatar
    25.4 is probably the stem, so it may have a threaded quill stem. 34mm is most likely the ID of the head tube, and 30mm is the crown race, which is the size used with 1-1/8" steerers. Based on those measurements you can fit a 1-1/8 steertube, plan on replacing the headset with a threadless and a new stem.
  1. 1.5 headset with large stack height
    By dthomp325 in forum Downhill - Freeride
    Last Post: 01-03-2013, 04:54 PM
  2. low stack height headset options??
    By mrsa101 in forum General Discussion
    Last Post: 06-20-2012, 05:37 PM
  3. headset lower stack height
    By schotter in forum Weight Weenies
    Last Post: 11-26-2011, 05:25 PM
  4. Low-stack Height Headset - S.I.R.9
    By dickt3030 in forum 29er Bikes
    Last Post: 09-06-2011, 09:33 PM
  5. Stack height spacer for 1-1/8" fork?
    By mwarner57 in forum Shocks and Suspension
    Last Post: 05-03-2011, 04:34 AM
