Im lookin for a new bike, ive checked out my LBSs, and out of the ones they have there, ive seen a few i liked. Now i just want a few more opinions on the components. I want it for general xc, but i dont want to go super light or anything that will limit me from doing 2-3ft drops.
To me it appears the bikes are similar, with the specialized having slightly better parts, for a lot more money. I dont know a lot about the parts, im wondering if they are that much better to demand the extra price, or if theres a premium because it has the specialized name. (spec posted below)
Also in the price range is the norco charger , which may be good too.
Thanks for any thoughts and opinions.
The bikes:
Specialized Rockhopper Comp Disc 2004:
Sale price: $1180CDN
Technical Specifications
FRAME A1 Premium Aluminum, disc only, double butted front triangle w/ 3-D box gusset, reinforced disc mount, externally machined HT, forged alloy drop outs w/ eyelets and replaceable derailleur hanger
FORK Manitou Axle Super, RTWD adjustable travel 70-100mm, adjustable rebound w/ alloy steerer
HEADSET 1 1/8" threadless, black steel cups, loose ball bearings w/ seals
STEM Alloy 10 degree rise, TIG welded, 13/15": 75mm, 17/19": 90mm, 21/23": 105mm
HANDLEBARS Alloy, 38mm rise, 9 degree sweep
TAPE / GRIPS Specialized Durango double density Kraton
FRONT BRAKE Shimano M-525 full hydraulic disc, resin pads, 6" rotor
REAR BRAKE Shimano M-525 full hydraulic disc, resin pads, 6" rotor
BRAKE LEVERS Shimano M-525 full hydraulic disc
FRONT DERAILLEUR Shimano M-510 Deore, 34.9mm clamp, bottom pull
FRONT HUB Specialized, Disc 32 hole w/ alloy QR
REAR DERAILLEUR Shimano M-570 LX
SHIFT LEVERS Shimano SL-M510 Deore
CASSETTE Shimano HG-50, 9-speed, 11x34t
CHAIN Shimano HG-53
CRANKSET Shimano Deore, Hollowtech arms, 13/15":170, 17-23":175mm
CHAINRINGS 44alloy/32s/22s, square taper, alloy hardware
BOTTOM BRACKET Shimano, BB-UN25 68x113mm
PEDALS Shimano PD-M505 clipless
RIMS Mavic XM-117 disc, 26", black
REAR HUB Shimano M-475 Disc, 32 hole, loose ball bearings, alloy Q/R
SPOKES 1.8mm (15g) black stainless, brass nipples, L260/R263mm front, L261/R260mm rear
FRONT TIRE Specialized Roll-X 26 x 2.0", aramid bead
REAR TIRE Specialized Roll-X 26 x 2.0", aramid bead
TUBES Specialized, schraeder valve
SADDLE Specialized Body Geometry Sport MTB
SEAT POST Alloy 30.9mmx350/400mm, micro adjust
SEAT BINDER Alloy QR, 36mm I.D.
Brodie Hellion 2005
Price $900
COLOUR Black Jewel
FRAME MTL 7005 Series Alum.
FORK Manitou Axel -100mm
HEADSET TH Intellaset
BAR/STEM YC-18mm Rise/4bolt
BRAKE Shimano Mech.Disc 6"
CRANK Shimano FC-M340
B/B Shimano BB-UN25
CHAIN Shimano CN-HG50
PEDAL Wellgo LU-934 Cage
FRT. HUB KK KDF3QR DISC
RR. HUB KK KDR-2S DISC
CASSETTE Shimano 11-30T 8-Spd
RIM Alex DM-18 Dbl. Wall
TIRE F/R CST-1435 26X1.95
FRT.DER. Shimano Alivio MC18
RR. DER. Shimano XT M750 SGS
SHIFTER Shimano Alivio MC20
SADDLE Velo VL-2043
POST Kalloy SP-368 2-bolt
The bikes:
CHAIN Shimano HG-53
Brodie Hellion 2005
Price $900
COLOUR Black Jewel
B/B Shimano BB-UN25
SADDLE Velo VL-2043
