Results 1 to 7 of 7
    Reputation: BoomerBrian's Avatar
    Best way to protect frame from cable scratches?
    My cables are scratching my frame. What is the best way to prevent this? Anyone have any good ideas?
    Reputation: mestapho's Avatar
    Frameskin, Helicopter tape, 3m clear film,
    All pretty much the same thing. I get mine as scraps from a
    local auto "clear bra" installation place.
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    I just use insulation tape in a colour that kind of matches my frame. You need to change it every six months or so, but it works and is cheap.
    Less isn't MOAR
    I just use the heavier type clear packing tape and double-layer it. I only put it in the high-wear areas but it does the job. It is clear so you really can't see it. Or, spend more money and get one of the above items.
    I found some good heli tape on ebay uk, good thickness aswell. Covers my whole bike now Think is was called Helicopter-Bike-Frame-Protection-Tape-1m-x-100mm-Thick-Version-FREE-P-P-
    wyrd bi ful rd
    Reputation: chinaman's Avatar
    I have used these on a couple of occasions ...
    BIKE PROTECTION TAPE 1m x 100mm - 3M HELICOPTER TAPE | eBay
    Reputation: Spicy.Mike's Avatar
    For Wires/Cables: Use same color duct tape and apply it to the areas of cable rub. Just simply wrap one small layer.
    For Frame/Parts: Use clear tape/color duct tape. Apply it the frame with 1-2 layers. Grip tape also works good. Just to avoid any tacky looks, match colors. Clear Tape is often the best.
    Easy Does It.
