Results 1 to 5 of 5
    Basic rear derailleur question
    Hey all, just wondering why rear derailleur cages come in short, medium and long lengths. I am
    building an older jeckyll and am trying to figure out which length cage i should run on it. It seems like
    I see a lot of longer cages on bikes, but am curious why you wouldn't use a shorter one so as to be less
    likely to snag it on something.
    Any help or advice is much appreciated!
    Jack
    In general - 1 front chain ring - short cage
    2 front chain rings - medium cage
    3 front chain rings - long cage
    Ok thanks, that might explain why my other cannondale with the typical 3 chainring setup and a medium cage doesn't shift that smoothly with the front derailleur, seems to take a fair amount of effort to get it to shift.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Quote Originally Posted by jackk View Post
    Almost certainly due to the adjustment of the shifting. I would change your derailleur cables and housing, re-adjust your shifting, and report back.
    The derailleur is dumb, it just does what the shifter tells it to do. So long as you have enough length (short, med, long) that your chain can reach all the gears, there isn't anything a long cage does that a short cage doesn't.
    Reputation: shiggy's Avatar
    Dec 1998
    Jack
    When to use a Long Cage vs Short Cage Derailleur?
    mtbtires.com
  1. What will happen? (Rear derailleur question...)
    By circlesuponcircles in forum Ibis
    Last Post: 11-10-2012, 11:29 AM
  2. Rear Derailleur question
    By dpo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-18-2012, 09:03 AM
  3. Rear Derailleur Question and HELP!!!!!!
    By boxedrn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-22-2011, 07:43 PM
  4. Rear derailleur question on my 29er.
    By toddeshpeter in forum 29er Bikes
    Last Post: 08-05-2011, 09:04 AM
  5. saint 800 rear derailleur question
    By daisycutter in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-13-2011, 06:55 PM
