Results 1 to 3 of 3
Thread: Bash guard size
    Apr 2013
    Bash guard size
    Hello
    First post here guys and needing a bit of help,i have bought a mountain bike second hand and it needs a bit work done on it.
    Firstly it needs a new bash guard how do i know which size to get it has 5 screws to hold it in place and the distance between the screws is roughly 77mm here is a link to the actual bike with specs.
    The Raleigh Dorado from Malleys
    Thanks for any help in advance.
    dru
    dru is offline
    Those cranks use a non standard bashguard. Typically the bash bolts to the chainring spider in the same place as the middle and big chainrings. Yours doesn't, and I have no idea where you'd even source a new one.
    Just ride the bike without one. Almost anyone here that runs a bashguard takes the big ring off first, otherwise they just run the three front rings with no guard.
    Drew
    occasional cyclist
    With a distance between bolts of 77mm, I believe that means the bcd is 130. There are cyclocross basguards that size, but they are usually pretty big (39T+) so you wouldnt be gaining much clearance
  1. Bash Guard for 120 BCD??
    By expatrider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-07-2013, 04:28 AM
  2. 2 x 10 and bash guard help
    By Highwaystreets in forum All Mountain
    Last Post: 08-15-2012, 10:14 AM
  3. Bash Guard 44T
    By diveinstructor in forum Ellsworth
    Last Post: 10-06-2011, 09:44 AM
  4. bash guard
    By blkcheerio in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-05-2011, 08:00 AM
  5. selecting bash guard size?
    By McKraut in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-06-2011, 07:16 AM
