Results 1 to 31 of 31
Thread: B1 Nirvana 1.0
    I-S
    I-S is offline
    Magurified
    Reputation: I-S's Avatar
    B1 Nirvana 1.0
    I thought I'd write up a bit about my new bike, because it's one hell of a bargain and not one that many people have come across. It's also rather hard to find much solid info about.
    So here it is, the 2007 BeOne (B1) Nirvana 1.0. The 2007 Nirvana is a horst-link 4 bar, with the pivot below and forward of the rear dropout on the chainstay. Note that for 2008 they have gone to a linkage single pivot. I paid £350 for the frame and shock from CRC, who had it down from £700. Unfortunately they sent it with the wrong shock (Rock Shox Bar, instead of the Ario it was meant to have). However, since I wasn't going to use the RS shock anyway, I was happy with the refund for that...
    Taking the frame out of the box and unpacking it the overwhelming impression is one of quality. The welding is very neat and nice beading, the paint finish is very high quality, the bearings in the suspension are smooth and there's no play. It exudes solidity... At 3.2Kg inc RS Bar (about 350g with mounting hardware), it's not light though. It's certainly heavier than the Marin Elite Monocoque (single pivot, East Peak/Mt Vision frame), equipped with a Fox Float RC, that I was riding before. In taking the Bar off the Nirvana, I discovered another bit of good attention to detail by B1 - the top shock mount, which is pretty wide, is a stainless steel single-piece mount similar to the heavy duty mounts sold by BETD and TF Tuned in the UK. Just a pity I took it straight out, but I ordered a similar mount from TF for my Fox shock. The next bit of quality that jumps out is the faced rear disc mount. During the build, there's other little details that you really appreciate - The zip-tie disc hose guides, the great finishing inside the headtube and bottom bracket, etc.
    I build the bike up with the components from my previous bike where possible, with the only changes being headset (from Cane Creek S2 to FSA Orbit Z semi-integrated) and the seatpost and clamp (it uses 30.9, rather than the 27.0 of the Marin). A quick rundown on the rest of the spec: Magura Asgard 100 forks, Magura Louise/FR brakes, Magura/Hope hubs, Mavic 717 & 36 spoke DT wheel builds, SRAM X9 RD, Shimano XT M760 FD, X.0/X.9 shifters, PC991 chain and XT M760 cassette, Ritchey Pro cranks and FSA platinum BB. Built up totally as pictured the weight is dead on 13kg. You could easily build it lighter - My build is completely about long term reliable high performance, rather than lightest weight.
    Once I acquired the mounting hardware, I fitted the Float RC that I had been using on the Marin, with a new DU eyelet bushing at one end (the other end was still tight and free of play). With the Float RC mounted with the lockout lever forward, the shraeder valve is partially hiding behind the rocker, making it very hard to fill the shock. Not a problem with the supplied Rockshox, and you could solve it by mounting the shock the other way around, but then the lockout lever would be between the rocker plates. I did take a dremel to the frame to cut out the cable stops to allow full-length cable housings to be threaded through. I am glad that I did, as it looks fantastic in my opinion...
    Setting up the drivetrain I discovered another problem - the XT Topswing mech fouls itself on part of the frame. I never liked the topswing mech due to its tendancy to lock up after catching a stone from the rear wheel, and only used it because it was necessary on the Marin. I've ordered an X.9 conventional front mech though, so that problem will be going away.
    Once on wheels, it's notable that the bottom bracket is a whole heap lower than the marin, mainly because the marin was freaky high (at about 14.5" to bb centre). This sits at about 13" which is pretty normal it seems. Once on it, it feels much better balanced - trackstanding is possible sitting down, with a low and rearward centre of gravity in the frame. Suspension action seems very linear and well damped, and unlike the single-pivot, it is barely affected by rear brake application.
    Getting it out on the trail, it is very much vice-free. It turns responsively and feels confidence inspiring. There is some pedal bobbing when you mash (I'm not using a platform shock), although it feels different to that of the single speed - it seems to push the rear wheel down when you push down on the pedal, rather than pull it up as the single pivot does. I did find that it felt easier to climb, although it was very windy today, helping to push up the hill (although later on some pretty fierce headwinds). In the windy conditions something really noticeable is that it is not badly affected by huge crosswinds - compared again to the sail-like Marin Monocoque.
    Getting on to some rougher downhills with some turns (nothing desperately tight though), the handling was quick and responsive. Something I did find in very tight turning was that the head angle is a little bit steep - worth noting that in B1s builds they put 5" forks on it, so that's probably the issue.
    The suspension was very well controlled, although I've not yet finished getting it set up - it needs significantly lower pressure in the shock than the marin did, and much less rebound damping applied (even with lots of rebound damping wound on, coming off a bump the marin could rodeo, pushing you off the seat) - and yet it doesn't bottom out. Getting just a little bit of air I felt much more confident in the B1, with its lower and more rearward weight distribution. One thing that it really did show up on the rougher stuff though was that it was crying out for a bigger, better fork than the asgards. If it were simple to switch over (ie no crown races to deal with), I'd put my 130mm Menjas from my singlespeed on it, because I think that would be a great combo. As it is, I will pick up a pair of Menja or Laurin for it at a later date (once my bank manager will talk to me again...).
    Mud clearance seems good, with plenty of room in the (disc only) frame around my 2.1" Fire XCs. Standover height is pretty good, and much more dignified to get on and off than the Marin.
    Is it all good news? The marin's high bottom bracket avoided pedal strikes, and I lost three pins out of my MG1s in a single ride on the B1. With the use of lockout on the climbs, the marin was perhaps a little more efficient, but nothing like as good to ride. The 17" BeOne fits me (5'7) much better than the 17.5" Marin (which always felt tall).
    To conclude, I think the B1 represents a very good trail bike for XC/enduro and places like Llandegla and Coed Y Brenin, chucking it around singletrack and berms, getting a bit of air and generally having fun. For efficiency in racing I suspect that the lighter Marin would take the crown, but I'd rather spend all day on the B1.
    Technical Specs (that aren't published):
    Shock: 165mm eye-to-eye
    Travel: approx 100mm
    Shock mountings - Top: 52mm M8, Bottom: 24mm M8
    BB: 68mm
    Headset: 1 1/8th semi-integrated (50mm OD, eg FSA Orbit Z)
    Seatpost: 30.9
    FD: 34.9 top pull (conventional swing recommended)
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Sweet bike bro
    Formotion Products
    http://www.formot
    Reputation: Scott@GO-RIDE.com's Avatar
    Does BeOne have a DH team anymore? They used to have a pretty sick DH bike, but I don't know if it was every available to the public. I know they weren't every in the US.
    Pivot Firebird
    Hightower 29
    Tallboy 3
    Pivot LES SS
    Salsa Beargrease C
    Giant TCX
    loved the b1 you built...found your picture after looking on chain reaction for full susser
    frame to build.....just took delivery of Nirvana 1.0 frame !!
    However wondered what sort of shock you would suggest for 6'1 19st ex rugby player
    to stick on to replace the cheap BAR 1.1 supplied. ...doing mainly riding in Clent Hills and Wyre Forest and occasionally Coed-Y-B in wales when visit father in law.
    currently swapped out most companents on GT avalanche 2.0 hard tail (rock shox 426 revelation forks being latest buy)....going to transfer to beone.
    don't laugh at weight ...5 knee ops and 5 kids takes it toll but still manage to cycle up the same hills just as good as 5 years ago and 2 stone lighter !!.
    Cheers Matt
    Jan 2005
    Quote Originally Posted by shaq attack
    Cheers Matt
    When making kids you dont need to be on your knees.
    Formotion Products
    http://www.formot
    I-S
    I-S is offline
    Magurified
    Quote Originally Posted by dogonfr
    Depends on your style really...
    On shocks, I am no expert. What I have found with the B1 is that it takes less shock pressure than my single-pivot marin did. Where I used 120psi on the Marin, 95 is right on the B1. I think that you would be able to use an air shock, in which case fox are the obvious choice - I'm using a float RC. Other shocks I'm interested in are the Magura Hugin and MX. For coil, I'd be looking Fox Vanilla R or RC.
    I never used the Bar either. Note that if you change shocks, you'll almost certainly need new mounting hardware as the Bar uses 12mm hardware, and fox (and most others) use 12.7mm.
    Jan 2005
    Quote Originally Posted by Isaac Sibson
    Maybe on a softer surface like a bed.
    Check out a Manitou ISX-4 sweet shock if you can find one in your length N stroke. Also the Evolver 6 is awesome.
    http://www.manitoumtb.com/items.asp?...=12&itemid=154
    Formotion Products
    http://www.formot
    Nice one....thanks for input guys.
    I-S
    I-S is offline
    Magurified
    Whilst we're on the subject, I guess I'll update on the bike...
    I replaced the XT with an X9 front mech and no more problems with frame/mech interference, although the angle of the cable into the SRAM mech causes the cable to rub inside the cable stop above. I've seen this on a friend's Gary Fisher with an XGen front mech, so I think the SRAM conventional front mechs have a particularly angled cable attachment. I've also found that the rocker traps and eats the outer for the front mech, although careful routing can avoid this. I'll dremel out the cable stop a little to fix this when I replace the chewed outer.
    I replaced the Asgard 100 with a Menja 130, went from 100mm 6deg to 90mm 10deg stem, and changed the Titec seatpost for a Thomson layback. These changes got my weight a little further back on the bike, which makes it much better. The geometry of the bike is unusual, with steep head angle, slack seat angle and short wheelbase but comparatively long chainstays. It is brilliantly maneuverable in tight switchbacks (Llandegla, are you listening?) but needs some care at high speeds where the steep head angle can make it very sensitive.
    The bottom bracket really is low it seems to me, but perhaps just because I got used to the Marin. I strike pedals quite a lot, so you might want to look at shorter cranks than the 175s I use. I'll be changing from the MG1s to NC17 sudpin IIIs when I can afford.
    Jan 2005
    although the angle of the cable into the SRAM mech causes the cable to rub inside the cable stop above. I've also found that the rocker traps and eats the outer for the front mech, although careful routing can avoid this.
    This is very common on 4 Bar's on the front der, you can allow more of a high loop going to the cable stop on the seat tube.
    Depending on your height or inseam be careful on the crank selection. Im 5'7" & ride 170 but i'm no XC climber either.
    Formotion Products
    http://www.formot
    I-S
    I-S is offline
    Magurified
    I too am 5'7. Shorter cranks just feel wrong to me, but I'm a big gear stand-up-and-mash kind of rider (My other bike is a singlespeed...). I imagine it's partly what you're used to.
    Jan 2005
    Ahhh I see one of them SS guys ayyyy, ride on.
    Formotion Products
    http://www.formot
    where did you get the bushe kit from ??? mojo ??....cant see it on wiggle/chainreaction etc
    I-S
    I-S is offline
    Magurified
    TFtuned.
    Dec 2008
    Hello
    I Have bought a B1 Nirvana 2.0 frame 2007 model and i would like to know if i can use for fork suspension the new 2009 Marzocchi 44 ATA 100-140mm travel ?
    Jan 2005
    Quote Originally Posted by stefan250
    Hello
    What is the rear travel?
    Formotion Products
    http://www.formot
    Dec 2008
    The rear travel is 100mm
    Jan 2005
    Wouldnt exceed 120 fork then.
    Formotion Products
    http://www.formot
    Dec 2008
    OK Thank You !!!!
    But if i use the 100-140mm that already have can cause the frame break or I'll change the geometry ?
    I have seen this bike with 130mm fork...
    initial post says shock length eye to eye is 165 contrary to a review in crc that states 190/50 for the shock.
    could you please verify
    thanx
    whats the differance between the 1.0 and 2.0?
    Jan 2005
    Quote Originally Posted by infinityzak
    http://www.beone-bikes.com/EN/products/nirvana.html
    Formotion Products
    http://www.formot
    I-S
    I-S is offline
    Magurified
    Quote Originally Posted by p_cycle
    thanx
    Shock length is 165.
    Nothing. The 1.0 is supposed to come with an RS Ario instead of the RS Bar, but mine came with the Bar. I had the price difference refunded.
    I-S
    I-S is offline
    Magurified
    Hello
    That will be fine. I'm now running a Menja 130 on mine, and B1 sold it with 130mm forks. It works better with that than 100mm.
    The one in the link is built up and not even the same frame
    Reputation: Broccoli's Avatar
    And what is the stroke?
    Do I need 6.5x1.5 float?
    Any updates on this frame? Looking at picking one up for myself in a few days. Hope to build up a xc race bike on the frame
    By the way, i have been in contact with BeOne reps.
    The claimed weight of the 17 inch frame is 2.4 kg and i was told the 19 inch frame was not much more.
    Quote Originally Posted by uncomplientspud
    So what is the exact shock size - 165x37.5mm (6.5x1.5)?
    I-S
    I-S is offline
    Magurified
    Yes, the shock is 6.5x1.5.
    Are you sure the claimed weight wasn't for the newer linkage single-pivot nirvana, rather than the horst-link model that this post was about? Mine certainly weighed in at 3.2 and maybe lost a bit in the change from RS bar to Fox float, but not a lot.
    From the Rep with some other information
    "The BB size is 68mm
    Replacement bearings will not be a problem, because we use non special sizes. So even if we canít supply you, there will be plenty of places where you can buy them.
    The rearshock size is 165mm.
    Normally you get several adapters with the shock to make the fitting right.
    Hope that clears it up.
    BTW 1.5 inches is equal to 3.81 cm or 38.1mm. so the stroke is 38. PLus from what i can find, almost all 165 shocks come in 165-38 size
