Results 1 to 8 of 8
    Reputation: veritechy's Avatar
    anti-seize for Ti frame?
    Hi,
    I have a Ti frame. A friend of mine puts anti-seize on his BB install.
    Just wondering if it is really necessary.
    Thanks in advance!
    Necessary, probably not. Highly recommended...yes.
    I thought Ti was pretty inert...
    I took off the BB with not much effort. I guess it may take years to bind. By that time I would have to change the BB anyway. Maybe necessary if you don't ride much?
    Supposedly Ti and Al will corrode together. I have left Ti bolts in Al frame and parts for a decade with no issue, though I use copper anti seize from the auto parts store now if I have it.
    Costs nothing, takes no time. Might as well use it, but if you don't you probably won't have issues.
    Quote Originally Posted by kroe View Post
    Thanks for sharing your experience! I ride regularly so probably going to maintain the hub once a year. If I'm going to store it I'll probably use the anti-seize.
    large anode (Al frame) + small cathode (Ti fastener) = no problem
    large cathode (Ti frame) + small anode (Al fastener) = rapid corrosion of anode
    whatever...
    Reputation: Cerberus044's Avatar
    Quote Originally Posted by steadite View Post
    Bingo. Like the poster above said the copper anti seize is cheap as dirt. You DO NOT want to have to try and remove a cold welded part. Its cheap insurance.
    OK, good advice. I looked through my boxes and I do have TI anti-seize I bought for my Blur suspension bolts. I guess not worth messing up a TI frame.
  1. Grease, Thread Lock, or Anti-Seize?
    By Tsetse in forum Tooltime
    Last Post: 04-23-2013, 07:45 AM
  2. Replies: 3
    Last Post: 11-27-2012, 02:32 AM
  3. Anti seize paste for Ti frames
    By Green Monk in forum Frame Building
    Last Post: 04-26-2011, 07:40 AM
  4. Titanium seatpost in a carbon frame...anti-seize or nothing?
    By appleSSeed in forum General Discussion
    Last Post: 04-18-2011, 06:02 AM
  5. Titanium seatpost in a carbon frame...anti-seize or nothing?
    By appleSSeed in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-10-2011, 05:55 AM
