    May 2013
    Advantage to large handle bars
    Curious how large in length handle bars affect steering? I would think it would give you finer control but perhaps slower response, is that correct?
    Reputation: mitzikatzi's Avatar
    Yes
    Most/many people add a shorter stem when fitting wider bars. The shorter stem "quickens" the steering (a wider bar slows down the steering)
    There is a lot of info on this on the forum already, just search look around.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    May 2013
    Quote Originally Posted by mitzikatzi View Post
    Yes
    Most people who are riding bars from 710mm to 780mm are running stems in the 80mm - 40mm range. Obviously the wider the bar, the shorter of a stem you can run. There is a balance between the two and when experimenting you should try and get cheap parts before dropping $150 on a new bar. Just my experience.
  1. Mechanical advantage of wider bars?
    By phsycle in forum Singlespeed
    Last Post: 07-12-2013, 12:18 PM
  2. Handle Bars
    By adamchrapowicz in forum 29er Components
    Last Post: 06-19-2013, 08:03 PM
  3. Newb here, what the advantage to shorter bars
    By redoc in forum Beginner's Corner
    Last Post: 09-30-2011, 09:09 AM
  4. handle bars
    By weightweenie in forum Weight Weenies
    Last Post: 09-26-2011, 06:29 AM
  5. Need to cut new handle bars
    By Graysku11 in forum General Discussion
    Last Post: 09-18-2011, 06:43 AM
