Results 1 to 18 of 18
Thread: ? about grips.
    ? about grips.
    My new grips feature two "patterns" around the grip. One pattern is "waffle" style, similar to Oury grips. The other is pretty normal small "diamond" pattern.
    My question - which pattern is "supposed to" contact my palms?
    Sorry about the dumb question.
    Thanks everyone,
    Terry
    Reputation: InvictaS1's Avatar
    Mar 2005
    what grips do you have? it probably doesnt matter how you set up the grips as long as they are comfortable.
    Quote Originally Posted by InvictaS1
    Sette (PricePoint) H-Type. They are inexpensive lock-on grips. My first try with any lock-on. I know lots of people luv 'em.
    Thanks,
    Terry
    Reputation: einstein's Avatar
    Bontrager made a very similiar set of grips that came stock on some higher end trek's a few years back. I distinctly remember those having the thicker waffle part at the palm.
    great minds think a bike
    Reputation: Treybiker's Avatar
    If they are like these, the "waffle" part faces away from you and downwards about 45 degrees. These are designed like motocross grips (Use the Renthal version on my Supermoto). The waffle pattern is designed for your fingers to have a better grip when wrapped around them. Aiming them towards your palm will put horrible pressure in small areas cutting into your palms. I've considered trying them out on my SS despite not haveing a "throttle".
    Treybiker
    Thanks for the excellent response.
    I am going to rotate the grips a bit as per your advice.
    Thanks,
    Terry - former Maico rider!
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Quote Originally Posted by Treybiker
    Check these out for the MTB
    http://www.pricepoint.com/detail/139...k-on-Grips.htm
    Formotion Products
    http://www.formot
    This guy
    Reputation: YZINGERR's Avatar
    i use motorcycle style grips on my bikes (actually they are for ATVs bacause both sides of the handlebars are the same size, unlike motorcycles).
    these are killer:
    RIDE
    This guy
    p.s. they are pro-taper pillow-top grips
    RIDE
    Quote Originally Posted by elder_mtber
    Treybiker
    Thanks,
    Becareful, you're about to reveal your age.
    This guy
    too late.... MAICO says it all!
    RIDE
    Jan 2005
    Quote Originally Posted by YZINGERR
    Penton
    Formotion Products
    http://www.formot
    Quote Originally Posted by dogonfr
    Penton
    Cool, the original KTM.
    Terry
    Weekend Warrior
    Reputation: daleksic's Avatar
    For me there is only 1 choice: OURY. I absolutelly love them.
    Quote Originally Posted by daleksic
    which Oury grips are you using? I'm in the process of finding that perfect (comfy) grip, thanks.
    Quote Originally Posted by acuracer
    Oh nevermind looks like they only have one model in the lock-ons type grips
    Weekend Warrior
    I'm actually not using lockon grips as i was going through about 4 pairs until i found the Oury. In lockon there is only 1 type available. In regular, slide on, they have different colors. The Slide on grips work just fine, are very soft and trust me, you will not loose your grip. As soon as mine wear out, i will get the lockon version.
    Jan 2005
    Be careful on grip size. I used to run the fat ODI Rogue till a semi pro DH'er suggested the Ruffian grip to me, WoW the thinner grip was much better. Found holding the bar took less effort & arm pump was gone which meant endurance & confidence went up also.
    Formotion Products
    http://www.formot
