Results 1 to 5 of 5
    '96 Mongoose Rockadile SX, headtube cracked x3
    BikePedia - 1996 Mongoose Rockadile SX Complete Bicycle
    I bought the above bike on Craiglist for $80 (loaded with high end parts):
    - Deore LX front & rear derailleurs
    - Deore XT crank
    - Mavic 238 rims
    - upgraded GT stem & bar
    - upgraded Manitou Forx U front fork (stock was Manitou Mach 5 XC..there was a recall for cracked dropouts)
    onlyl 26 lbs.
    Unfortunately, I shortly discovered 3 cracks in head-tube!! 2 on top, & 3rd on bottom (long one, goes almost to middle of head-tube). See pics.
    I scanned the Web, & 90% say the frame is kaput. There were some instances of repair: drill a hole at end of crack to stop any further cracking. Use dremel bit to gouge a valley in crack & weld it up. I DID find an interesting thread on weld repair:
    Cracked Head Tube - FIXED - evolutionm.net
    They cut the metal beyond the crack (getting rid of the fatigued Al), & filled it in via weld.
    The Mongoose Rockadile SX is a NICE frame, so I'm considering a repair. But, THREE cracks! Maybe better to just find a new frame (Nashbar, Performance, Leader) & start over.
    Any ideas of a lightweight frame..good price?
    BTW, I approached the seller about getting some sort of resolution..he refused!
    Attached Thumbnails Attached Thumbnails '96 Mongoose Rockadile SX, headtube cracked x3-5i95f15jf3l93n73hfc6he34a835f7b42141b.jpg
    yeah you have to be careful when buying off craigslist. i sit there like an ******* looking things over so i know i'm not getting ripped off. i have a nashbar frame right now, its been good so far. i got it dirt cheap when they had a sale, so yeah... that's always an option. i see frames pop up every now and again. i bought this frame to hold me over until i found something i liked cheap, but until then i'll keep rocking this one. i feel like fixing that is just kind of dangerous.
    Former Bike Wrench
    The Rockadile is an average frame that is 16 years old, easily replacable with a $100 frame that should fit all the parts.
    Sette Reken Alloy Hardtail Frame at Price Point
    Quote Originally Posted by mtnbiker72 View Post
    How would you compare the Sette/Reken (4.5 lbs for 18") with the Leader (4.21 lbs for 20"):
    BlueSkyCycling.com - Leader 510H MTB Frame
    Former Bike Wrench
    Quote Originally Posted by chimpanzee00 View Post
    For that price...take the Leader(assuming you need a 15" or 21"), looks like most parts will swap and you need a new headset anyway based on your pictures.
