Results 1 to 5 of 5
    Reputation: Thinkly's Avatar
    1998 Trek 930 Geometry
    I am trying to locate geometry information on my "new" trek 930 frame. I just bought this frame and built it up. Can't find any info for the geometry online anywere including the vintage trek site.
    I emailed trek a couple times and they have never responded.
    Lionel Hutz, Esq.
    Reputation: Thirdrawn's Avatar
    Here ya go. Straight from the 1998 catalog:
    And, so you know which measurement is what:
    Hope this helps.
    2007 Trek Fuel EX 8
    1999 Trek 7000 --- Dragonfly Green = Sexy
    2002 Trek 2100
    2008 Felt New Belgium Cruiser
    Former Bike Wrench
    I was also going to say 71* head tube, 73* seat tube...BUT
    That would have been with an RS Indy S which was running about 63mm of travel. It appears from the picture that there is a fairly recent RS Judy J3 on there which would be at least 80mm of travel which would knock it back about 1/2 of a degree.
    Lionel Hutz, Esq.
    Quote Originally Posted by mtnbiker72
    I thought about mentioning that his new components would change at least two of those readings. But, I figured that he knew adding length to the shock would slacken the head angle.
    In any event, the original spec was a 50mm RS Indy S. I'd say he slackened the HA at least a degree - probably closer to two. But, I'm sure he was aware of that when he deviated from original spec.
    2007 Trek Fuel EX 8
    2002 Trek 2100
    Thanks for the info. I wasn't fully aware that the fork with more travel would change the head angle so much. I am interested to learn that. I suppose that would mean this frame wouldn't require a suspension corrected rigid fork if i choose to go rigid with it?
    Somehow i was thinking this year of frame was designed for a 80mm fork. I'll do some further digging.
    Still i have a couple of questions regarding geometry. I bought this frame because i wanted a frame that was at least closer to my 07 Trek 6000. That frame is a 21.5" c-t and the Trek 930 frame is a 21" c-t.
    I knew the eff top tube length was a little shorter on the 930 but was hopeful it would put the Brooks saddle back almost as far as the 6000. It didn't turn out to be that way. I am comfortable on the 930 but am constantly wanting to push those saddles back more because the rails are so short.
    Can you discuss how the two geometries compare?
