Results 1 to 3 of 3
    Reputation: 702Biff's Avatar
    Dec 2012
    11/32 9 speed Cassette
    Stupid Question: I am replacing worn drive train components. Can I purchase any 9 speed 11/32 cassette or do I need to stick with sram. I have an sram x7 dérailleur.
    Bicyclochondriac.
    Quote Originally Posted by 702Biff View Post
    In the future, this type of question should go in the "Drivetrain" board.
    Assuming what you already have is a 9 speed cassette, then yes, you can use any SRAM or Shimano 9 speed cassette.Their 9 speed cassettes are interchangeable. You can even go 11-34 if you wish. You can use either brand of chain and chainrings as well. Mixing brands with these components is fine.
    Dec 2012
    Cool thanks!
