Results 1 to 8 of 8
    Reputation: onda's Avatar
    Oct 2007
    100mm Shocks for 1999 FSR Comp Frame
    I have a 1999 Manitou SX/R that I badly need to replace, and I want to know how much travel I can upgrade to before my 1999 Specialized FSR Comp turns into a chopper.
    Can anyone measure (or know because I can't find any relevant dimensions on the web) their 100mm (I'd take a 120mm too if someone was so generous) shock from the middle of the axle/skewer to the bottom of the headset?
    My Manitou is 17 1/2".
    Anybody upgrade one of those 2006/2007/2008 front shocks like the Fox Float, RockShox Reba, with all those fandangle lockouts, blowoff valves, multiple travel on their old frame and care to share?
    Cheers,
    Arto
    Reputation: dnlwthrn's Avatar
    You mean fork, right? The shock is for rear suspension, the suspension fork is for the front... That said, you're saying your A2C (axle to crown height) is 444-445mm. That's the number you need to compare different forks. I'm guessing you are currently running between 65-80mm of travel. That said, you "should" be able to run a 100mm fork without feeling too chopped out, but you'll need to try it for yourself to be sure. I'm running a 100mm fork on my 98 Fisher (originally rigid) and its way slacker than it was originally. I've gotten used to it, but I doubt my frame would be warranteed if it broke.
    When you factor in sag, going from 80mm (my guess on your current fork) to 100mm is not really much of a change.
    Warning: may contain sarcasm and/or crap made up in an attempt to feel important.
    Oct 2007
    Going further to 120/130mm
    thanks for the help.
    Arto
    Born to Riiiide
    Reputation: Student Driver's Avatar
    Remember that you can go plus or minus 10% of the stock fork's travel before you void the warranty on the frame. Just something to think about.
    1997 Specialized Stumpy Pro
    1998 Specialized Allez Epic
    2007 Specialized Stumpy FSR Elite
    2010 Specialized Roubaix Expert
    Oct 2007
    lifetime warranty from Specialized?
    Is my 1999 frame still under warranty?
    Born to Riiiide
    If you're the original owner, then the front triangle may (well, should) have a lifetime warranty on it.
    I Just Ride....
    Reputation: mtbbrian's Avatar
    Sep 2002
    I have a 99 FSR Pro, and a few years ago I put on a Marzocchi MX PRO w/ETA which has 105 mm of travel.
    Plus I have the MRP linkage on the back.
    I haven't had any problems.
    Brian
    Artistic Mountain Bike Photography
    My MTBR Gallery
    "I Ride my bike, to Ride my bike...."
    From a Zen proverb
